Starting issue
Old Mar 31, 2013 | 06:17 PM
kilich's Avatar
kilich
Default Starting issue
Okay, I have a 1985 Corvette, When I go to start it in the morning it will crank crank crank crank crank crank and crank then it will fire, Fuel pressure is good, Cap and rotor is good, Plugs are good... If I drive it around and then go to start it, it does the same thing, Then If i park it in the garage like last night, i go out there and it starts right up instantly.. I am confused and need help. Anything will be greatly appreciated. Thank you.
Old Mar 31, 2013 | 06:43 PM
LoneStarV's Avatar
LoneStarV
http://forums.corvetteforum.com/c4-t...nk-solved.html
Old Mar 31, 2013 | 06:45 PM
kilich's Avatar
kilich
Just read that, Thank you
To Starting issue
