'91 Horn problem
Old Jun 19, 2002 | 12:08 AM
Vettman 1's Avatar
Vettman 1
Default '91 Horn problem
My horn suddenly quit. It's not the fuse, doesn't appear to be the relay ( if it's the 2nd from the left as you sit in the pass. seat) Anyone deal with this before?? :confused:
Thanks,
P.S. It's not the horns themselves.
[Modified by Vettman 1, 10:09 PM 6/18/2002]
[Modified by Vettman 1, 11:03 PM 6/18/2002]
Old Jun 19, 2002 | 09:32 AM
Vettman 1's Avatar
Vettman 1
Default Re: '91 Horn problem (Vettman 1)
ttt
Old Jun 19, 2002 | 01:45 PM
PTz-92-LT1's Avatar
PTz-92-LT1
I took mine off and sprayed it real heavy with WD 40. It worked well for a couple of months then quit again. Did it a second time, and it worked for another coupel of months.
End of story...got some replacements from a bone yard.
Old Jun 19, 2002 | 02:02 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: '91 Horn problem (PTz-92-LT1)
I got new horns from NAPA for abou 30 bucks total.. I always thought my C4 had such a weak sounding horn.. the new NAPA horns DEFINATLY made up for that!! :)
Old Jun 19, 2002 | 08:07 PM
KYVette90's Avatar
KYVette90
Default Re: '91 Horn problem (MarkLT1)
Could be the horn relay or a bad ground in the steering column. How do you know that the horns themselves are not bad? Water tends to get into them and causes them to rust out on the inside. :cheers:
To '91 Horn problem
