84 4+3 Thermostat question
Old Apr 1, 2013 | 11:25 AM
glava2876's Avatar
glava2876
Default 84 4+3 Thermostat question
My cooling system is in great shape and the Vette will run nice and cool. Driving, after installing the ported intake and the 160f thermostat that came with the Hypertech chip, on the NYS Thruway on a 45f day, it wouldn't get above 168f -so no overdrive!
The od needs about 185f to operate, but when I was looking for thermostats, I could only find a 180f -will I be able to find a 185f or will this 180f do like the 160f and run warmer and hopefully go above 185f?
I just figure if it will run cooler, why go with the stock 195f -or am wrong?
Thanks.
Old Apr 1, 2013 | 01:27 PM
Ghast's Avatar
Ghast
Strange, in my '86, OD kicks in at 120f.
Old Apr 1, 2013 | 01:28 PM
c4cruiser's Avatar
c4cruiser
A 160 degree 'stat doesn't determine the coolant temp. That value represents the temperature the coolant needs to be in order for it to open. The Hypertech chip will change when the fans come on based on temperature.
I would install the stock (correct) thermostat for the car. In addition to allowing the proper coolant temp for the OD to operate (I think the temp is 176 degrees), the higher coolant temps aid in reducing emissions. If the car has to be smogged, the chances are the low coolant temp will cause the car to fail the test.
Old Apr 1, 2013 | 01:29 PM
c4cruiser's Avatar
c4cruiser
Coolant temps for OD operation is different for the various years: 176 for '84, 140 for '85, and 122 for 86-88.
Old Apr 1, 2013 | 01:42 PM
glava2876's Avatar
glava2876
I realized that the stat doesn't determine the temp -but if the car will run at 180 -185 degrees on the highway, the stock 195 degree thermostat will make it run hotter because it won't open?
I know that the higher temperature thermostat in 84 was to aide smog reduction, but does that also have a negative impact on performance?
My vehicle is old enough that it is smog exempt.
Old Apr 1, 2013 | 07:04 PM
93Rubie's Avatar
93Rubie
LOL, I never get tired of these threads and all the BS info about thermostats and engine operating temperatures.
T-stat determines MINIMUM engine operating temperature ONLY.
Last I checked MOST modern engines operate at higher temps than even my LT1 does.
Which FYI, runs 192-194 down the highway all the time. Which FYI, makes about 95 more HP than your 84. Stick a stock t-stat in it and be done with it.
I know for a fact many other engines operate much hotter. My new Sentra runs 200+ all the time once warmed up. Makes 124hp from 1.8L and gets 40+ on the highway. Hell of a lot more efficient than the old L83 and runs hotter....catching my drift, put the dang stock t-stat back in the car. End of Discussion.
Old Apr 1, 2013 | 08:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes. If it runs 185 now, with you 160 stat, then it will run hotter (at least 195) with a 195 stat.
No negative effect on performance. Lower operating temps allow you the opportunity to exploit methods to get more power (more so in the L83 than in an LT1). In other words, changing the operating temp won't by itself, or directly affect power in any meaningful way. Unless I am misunderstanding your mission and goals, I agree with those who are suggesting to run a higher temp stat.
Old Apr 2, 2013 | 05:47 PM
glava2876's Avatar
glava2876
It takes me a while, but I got it now and picked up the 195 thermostat and will put it in Thanks to everyone for your input!
To 84 4+3 Thermostat question
