Leaves me stranded!!!!!!!!
Old Jun 19, 2002 | 12:19 AM
twogonzo's Avatar
twogonzo
Default Leaves me stranded!!!!!!!!
When I drive my 87 somewhere, let it sit for about 10 min and try to leave the sucker won't start, and I mean nothing, no click, nothing. When I turn the key to the start position the amps read 11.8. Help!!! I've already replaced the alternator and the battery with one of those expensive gel optima's. Any suggestions? :(
Old Jun 19, 2002 | 12:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Leaves me stranded!!!!!!!! (twogonzo)
First verify that the battery and alt connections are sound.
Then pull the alt and have it checked; if OK have the battery checked; if OK look for a short.
Old Jun 19, 2002 | 12:31 AM
merrick's Avatar
merrick
11.8 Amps? You probably mean volts. It is probably a bad battery ground and/or engine ground. If those are good, you probably need a new starter silenoid.
Old Jun 19, 2002 | 01:15 AM
Rich_01659's Avatar
Rich_01659
Default Re: Leaves me stranded!!!!!!!! (merrick)
does your ignition key get hot? is it worn out (maybe abused a bit) ..... my point is it could be your VATS (if 87 has Vats) if so it could be time for a new key.
Old Jun 19, 2002 | 08:51 AM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
11.8 volts when you turn you key to the start position is good - your battery is only 12 volts, so I would rule out the battery and the alternator.
Does this only happen when the car is hot?
Does the car start up great when it is cold - like first thng in the morning?
If you answer yes to the two questions above, then you are suffering from a heat soak problem with your starter.
You might be able to get by putting a heat shield around the starter, but you might have to buy a brand new starter.
I had the same problem with my 86 and the new starter with heat shield was the solution.... No more problems... I got my AC Delco starter from Oreilly's and it has a lifetime warranty - If you can get one with a lifetime warranty, I would get that one.
Old Jun 19, 2002 | 05:14 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Leaves me stranded!!!!!!!! (Husker Vette)
[QUOTE]
If you answer yes to the two questions above, then you are suffering from a heat soak problem with your starter.[QUOTE]
:yesnod: That would be the first thing I would check. I've had that problem numerous times in the past with other cars. :cheers:
Old Jun 19, 2002 | 08:16 PM
jfb's Avatar
jfb
If your VATS is not the cause of a no-crank, you will be able to hear the start enable relay click behind the center of the dash when you hit the starter position on the ignition switch.
[Modified by jfb, 6:18 PM 6/19/2002]
Old Jun 19, 2002 | 11:10 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
If it's the heat soaked starter, your starter is probably too far gone now to just shield, as someone said, replace and shield it and you'll be fine.
Try carrying an extra key and wait a few minutes and try to start it with the duplicate. That would indicate it's a bad chip on your key. If that doesn't work, have someone give you a jump cuz it's probably the starter. I had this happen several times and I don't know why but a jump worked every time.
[Modified by thrills, 9:10 PM 6/19/2002]
Old Jun 20, 2002 | 01:29 AM
twogonzo's Avatar
twogonzo
Default Re: Leaves me stranded!!!!!!!! (thrills)
Thanks guys, I'm going to try all of those Ideas. I'll let you know this weekend. This sight is great, thanks to you guys. :yesnod:
Old Jun 20, 2002 | 01:31 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I get 12.7 with the key on, engine off and 14.1 at idle.
Old Jun 20, 2002 | 01:56 AM
Sal Collaziano's Avatar
Sal Collaziano
I used to get this with an 88 Formula. It turned out to be the alarm system...
Old Jun 20, 2002 | 03:35 AM
DMONSVETTE's Avatar
DMONSVETTE
Mine ended up being the VATS, installed the VATS bypass from MidAM.
:cheers: :seeya
Old Jun 20, 2002 | 12:46 PM
Jim-K's Avatar
Jim-K
When my VATS acts up, usually about once every couple of months, disconnecting the battery for a minute or so will fix it. Try that.
Old Jun 20, 2002 | 12:57 PM
chilihed'95coupe's Avatar
chilihed'95coupe
Default Re: Leaves me stranded!!!!!!!! (Jim-K)
One other thing for future reference. Those Gel cell batteries are pretty much junk as far as longevity is concerned. They are very sensitive to temperature, and also have been known in other applications to start fires. Trust me, go with a wet cell battery next time.
Old Jun 20, 2002 | 01:03 PM
scorp508's Avatar
scorp508
Is the car TRYING to crank over? Or nothing? Do you get any clicking? 11.8 volts while trying to start is plenty for an '87. Typically I can get the car to start with as low as 11.2 volts even if it isn't pretty. As others have said, your starter is probably heat soaked. I would look into getting a smaller starter. I think 1988 has the first year of the smaller ones, and it should bolt up fine! :cheers:
To Leaves me stranded!!!!!!!!
