supercharger help
Old Jun 19, 2002 | 12:50 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Default supercharger help
Does anyone know of a twin screw supercharger system for an 87 L98. Spoke with the folks at Whipple. They do not have a system for my application.
Seems like some of the companies only have systems starting with the 1988.
Thanks :confused:
Old Jun 19, 2002 | 04:48 PM
GRX's Avatar
GRX
Default Re: supercharger help (STREETKNIGHT)
Carroll Supercharging Company is what you want: http://www.carrollsupercharging.com/ . You should go with a centrifugal design blower...much more efficient than ANY other design (for automotive purposes). Good Luck! :chevy
Old Jun 19, 2002 | 04:49 PM
GRX's Avatar
GRX
Where are my manners....welcomw to the forum! :cheers:
Old Jun 20, 2002 | 01:09 AM
STREETKNIGHT
Default Re: supercharger help (GRX)
Thanks for the info. I have looked into the Carroll website. Might be my only choice. Really wanted the Whipple type more for the aesthetics and low end torque. Gives a pretty good HP increase, and no lag. Oh well :sad: If something else doesn't crop up guess I'll be lookin' into the Carroll unit anyway.
Thanks again for the information. :cheers:
Old Jun 20, 2002 | 01:23 AM
bill mcdonald's Avatar
bill mcdonald
:confused: :confused: :confused:
Why does it work for an 88 and not an 87?
Old Jun 20, 2002 | 02:53 AM
STREETKNIGHT
Default Re: supercharger help (bill mcdonald)
Beats the heck outta me :confused: That was all I saw on the Whipple web site...started at 1988 and went up from there. The rep from Whipple said 1) they do not make a set up for my application citing a too high compression ratio, and
2) They do not do custom applications :crazy:
Oh well...have spent the last hour or so looking over the Carroll site. Looks like it may be my best bet for all around performance/drivability. Just kinda wanted the "blower" look...asthetics.. :D
Old Jun 22, 2002 | 09:07 PM
gcrouse's Avatar
gcrouse
Isn't it your compression ratio 9 or less with iron heads? Later cars switched to aluminum heads and ran even higher (my 89 had 9.5:1).
I'd check back with their tech people- If that's the only issue, I don't see why can't run a Whipple with 5-6 psi of boost. ATI makes intercooled kits and lists the same one for all 85-91 L98 vettes: www.procharger.com
But if your CR is too high for a Whipple, it's too high for any centrifugal blower also...
Old Jun 27, 2002 | 06:38 AM
Janaelen's Avatar
Janaelen
Default Re: supercharger help (gcrouse)
Some of the '86 corvettes had aluminum heads. 87+ had aluminum.
STREETNIGHT,
Go with centrifugal, much easier of an install and the efficiency is MUCH better. Whichever you choose, be sure to get an air/air intercooler for it to get a little more out of the boost (colder intake allows you to run a little more boost).
To supercharger help
