Shifting Technique
Old Jun 19, 2002 | 12:59 AM
merrick's Avatar
merrick
Default Shifting Technique
It is simple, but I didn't think about it before. I was watching Motor Trend and the driver was shifting like this: While winding out one gear, he was putting pressure on the shifter to come out of that gear to go to the next. I don't really know if that is faster than shifting all in one motion, but it may reduce miss shifts when under hard throttle.
Old Jun 19, 2002 | 02:54 AM
GRX's Avatar
GRX
Default Re: Shifting Technique (merrick)
Do that all the time and you'll prematurely wear out the synchros... :eek: Race car stuff :jester
Old Jun 19, 2002 | 02:05 PM
cire96's Avatar
cire96
It's a horrible practice. It will cause gear face wear and may (as already pointed out) be bad for the syncronizers. The bottom line is that no pressure ought to be put on the linkeage until you're ready to shift. When you are, grab the stick like you mean it and put some a-- into getting it to the next gear. BTW, IMHO, C&D is a crummy place to get any really good racing input. Cire96
Old Jun 21, 2002 | 01:54 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Re: Shifting Technique (cire96)
:yesnod: :yesnod: :yesnod: :cheers:
Old Jun 21, 2002 | 02:21 AM
NoWorries's Avatar
NoWorries
I push down the button on top, pull it backwards to the OD symbol, and go.
Haven't missed a shift yet. :jester
Old Jun 21, 2002 | 02:22 AM
ColinOpseth's Avatar
ColinOpseth
Default Re: Shifting Technique (NoWorries)
Hmm, same here.. That OD symbol sure knows how to powershift fast :jester
Old Jun 21, 2002 | 02:23 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Same here !! Funny how that works !!
Old Jun 21, 2002 | 08:56 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
1st thing, anything from Motor Trend is worthless.
Now did he state he was doing that or did you observe him doing that?
Seems to me that you have more of a chance to miss a shift that way. What if you hit a bump and you knock the shifter into neutral, now you have to worry about where the shifter was supposed to be and where you were going with it.
Shifting is a natural thing, you shouldn't have to think about it.
To Shifting Technique
