Flowmaster 3 chamber question
Old Jun 19, 2002 | 03:14 AM
ravinwolf's Avatar
ravinwolf
Default Flowmaster 3 chamber question
I installed a new 2 1/2 Y pipe and 2 1/2 flowmaster mufflers and my question is will I get better performance if I get rid of my high flow cat? Someone told me that when using a 3 chamber flowmaster you get better performance when you lose the cat.
Old Jun 19, 2002 | 04:08 AM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: Flowmaster 3 chamber question (ravinwolf)
It depends if you want to be emission legal... :D Lossing the cats, perhaps more performance, but isit that drastic, I'd be bold enough to say probably not... my humble opinion.
If you are looking for a little more growl , I've always used the 2 chambers lef the cat s in... on my 95 and 96 Iwenttwo chamber and lost the resonator...
mo
Old Jun 19, 2002 | 05:59 AM
pablocruise's Avatar
pablocruise
I have the 3 chamber Force II's installed right now. (no cats at all)
It has less deep rumble/bass than when I had the 3 cats. Performance? Uh....I did so many other mods at the same time that I can't accurately answer. It does flow/breathe alot more freely tho!!! L98's like that. You don't mention if you have a LT motor or L98 or ??
*Disclaimer: any California Air-Quality Resources Board officials reading this.........my car is for off-road use only and never driven on highways or roads :rolleyes: :lol:
Old Jun 19, 2002 | 06:10 AM
ravinwolf's Avatar
ravinwolf
Default Re: Flowmaster 3 chamber question (89 Paul in Cal)
I have a 87 vette. L98, the mods I have done are tpi air foil, open air lid with k&n filter, throttle body heater bypass, air pump removal, stage 2 fast chip with 160 stat, high voltage coil, bosch 4 plugs, shaved the heads a little when I blew a head gasket. I have no pre cats, just the high flow that connects to the rear y.
Old Jun 19, 2002 | 06:36 PM
ravinwolf's Avatar
ravinwolf
What about installing a new set of headers, and which one's will best fit my car.
To Flowmaster 3 chamber question
