turn signal stuck on fast
Old Apr 6, 2013 | 11:00 AM
DHobbs's Avatar
DHobbs
Default turn signal stuck on fast
(1990)
Essentially it is like there is a bulb out on each side. But there is not. I can hear the relay ticking fast.
I work a lot and haven't had a chance to look at it. Was wondering on where I should start.
Im thinking relay.
Old Apr 6, 2013 | 11:20 AM
c4cruiser's Avatar
c4cruiser
Could be a bad turn signal flasher. They are cheap so that could be a good start.
Old Apr 6, 2013 | 12:19 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by DHobbs
(1990)
Im thinking relay.
What happens with 4 - ways? If it seems functional with the 4 - ways then I'd do a flasher just to do it! You actually could have a bad socket or maybe just poor contacts in sockets. I'd consider cleaning all of the dried out lubricant in the sockets and replace the bulbs as just a form of maintenance. If you've mixed LL (long life) bulbs with a mix of just what was there it might create an issue. Make all of the bulbs match if you're replacing them.
Old Apr 8, 2013 | 04:15 AM
Cliff Harris's Avatar
Cliff Harris
I've seen turn signals flash fast when the brake and light filaments were shorted together inside the bulb.
To turn signal stuck on fast
