Best Remote Oil Filter kit
Old Apr 7, 2013 | 05:51 PM
Baller's Avatar
Baller
Default Best Remote Oil Filter kit
Several kits out there and I was wondering which ones those who've done would recommend or avoid?
Thanks.
Old Apr 7, 2013 | 06:20 PM
LoneStarV's Avatar
LoneStarV
Milodon but not cheap by the time you buy the remote with hoses then the adapter required on the right side of the screen. Mr. Gasket is much cheaper. Used it on a couple of cars. Depending on where you plan to mount the filter you may need longer hoses. You can use braided lines with AN fittings to the custom length you need. It would suck to buy that Milodon then find out you need longer hoses than what come with it. I put a Mr. Gaket on a Ford F150 that has the filter STUPIDLY mounted at an angle on the front drivers side of the engine. I bought the Mr. Gasket kit. Decided where i wanted to mount it on the frame. Measured the length lines i needed and had a shop make them. Cut me a nice price on them. Worked great never leaked and made changing the oil a breeze.
http://www.summitracing.com/parts/mi...FQTonAodD1cAcg
Old Apr 7, 2013 | 07:55 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I used Canton pieces and made my own line with AN fittings and an eBay oil front mount cooler. Make sure you flush the cooler BEFORE you install it.
Old Apr 7, 2013 | 10:03 PM
Baller's Avatar
Baller
Thanks Guys. I thinking I'll get something similar to the Mr. Gasket just to get the adapter and remote filter fixture and then custom make the hoses. definitely want steel braid.
I won't ask how you know....
To Best Remote Oil Filter kit
