On an old post under radiators someone mentioned a Jeff Kopp at Superior Chevy for an OEM radiator. Unable to locate him. Bottom line I would prefer to get an OEM radiator for a 94 manual Tranny. Part # 52460411. Any suggestions?
Mid American out of stock $190.
Dewitt aluminum $495
Tonkin GM $275
Tonkin GM $275
Thats all I can find after 2hrs on the net
Just bought one at advancedauto for $155. Not OEM. The spout for the top house was 1/8" too small. The OD on mine is 1 3/8"
Try NAPA - Part Number: NR 2228 $164.00 - website lists at the warehouse so it should be available the next day. Good luck. After a second look it appears to be for an automatic but if you call them maybe they have the manual available.
This may work. I went to the NAPA site and they do not specify if their measurements are ID or OD so I called a local NAPA. The guy said that in his puter his OD measurements are the same as mine stated above. He said he can have it by noon tomorow. Will up date thread then. thanks
A service radiator for a C4 has been a "single part #" for years. The cooler for the A4 is just there for the ride on an M6 car.
