Good afternoon! I am a brand new user, so best regards to all. I have the option of acquiring an LT-1 car which I'm told has a spun bearing due to running out of oil. I don't know how long the engine was run this way or if it was driven until it quit. What's the worst case for repair? I'm thinking a new shortblock, at least. Ideas? Sources? (Nashville,TN) Thanks for your input.
Welcome to the forum. A new short block would probably be the most cost effective option for you. If the motor was run with no oil I would think the crank and all of the bearings were bad. I don't know for sure if it would work in an LT1 car but a GM ZZ4 short block runs around $1900. It comes with a warranty also. Good luck with the car. :cheers:
The crank might just need to be cut which would be about $125 plus new bearings. But if I had it apart that far I would go over the whole motor. All new bearings, rings, pistons, have the heads gone over and such.
i'd just rebuild the engine i'm in the process of doing exactly the same thing, i'll list a partial price guide of what you can expect. in the next week or two i'm going to do a detailed post on a rebuild with a lot of pics. you can turn your crank for $100 a 10/10 cut would be good unless yours is seriously injured. you can reuse your PM rods for $100 in machine work and $45 for ARP bolts, OR be smart & buy forged 5140 eagle I-beam rods with arp bolts for $199 off ebay or dyno-flo1.com. pistons, unless you are going to beat the holy hell out of it forged aren't needed & have oil consumption problems as well as the engine wearing out faster from the large ring/cyl gap you need. if you use a lot of No2 or plan on making over 450hp forged might be smart. under 450hp and under a 100-150shot a GOOD hyperutectic piston would work better. they seal wonderful and burn no oil. the one that fits the gen 1 & gen 2 corvette engines so well is made by speedpro. it's a teflon skirted 4 valve relief piston. with the stock heads and a .039 head gasket & a block decked to zero your compression is right on. cyl quench is almost ideal as well. the pistons are $150 from summit or jegs. hastings plasma moly rings are very easy to setup & seal wonderful $79.95 under the summit brand ring in there catalog, listed as the street strip ring. having a 3 angle valve job done and some bowl hogging is about $150 and definatly worth it. you can reuse your stock valves or buy manley race-flo necked valves in stock size for $152 that flow better. lifters are your call to replace or not, a low mi engine may be safe to reuse your old ones however a brand new complete kit from GM with everything is $210. if this were my car i'd do a cam change as well. many people have made the GM zz4 cam pass emissions & you would DEFINATLY get a BIG HP increase for $200. comp cams makes some really choice cams targeted at the LT1 but i haven't heard if anyone has passed them or not. the duration split is close & knowing how fast comp makes most there cams it's questionable if they would pass. if anyone knows email me. machine work for all the above will run around $1500 at a shop worth there weight in gold. i think your total will be over $2000 but you can probably keep it under $3000 with some skill. also you will have a brand new engine in the car this is worth some serious value by it's self. remember..if your the type who likes to do ANY mods to a car change that cam when the engine is out !! you have 30-50hp sitting there in a $200 bill.
Welcome to the forum :seeya I would go with a ZZ4 short block. forged crank pm pink rods, hypertetic pistons, 4 bolt mains, set up for a roller cam. warrenty..
