Starting problem
Old Apr 9, 2013 | 07:00 PM
dieseltech's Avatar
dieseltech
Default Starting problem
1986 C4 with 4+3 trans. and less then 35000 miles. About 50% of the time when you shut the car of and run into a store for five minutes and come back out the car won`t even attempt to start. Does not draw down voltmeter ,which reads fine, at all. Will fire right up with a jump every time even though the battery isn't dead. Battery new and kept on battery tender, alternator new, starter cables clean and tight. Thanks in advance for your input.
Old Apr 9, 2013 | 07:13 PM
leesvet's Avatar
leesvet
what do you mean by not starting?
A. No starter motor? just clicks?
B. No engine firing even tho its cranking?
C. nothing at all happens when the key is turned?
Are you famliar with VATS???????????????????????????????????? ??????
learn about it.
In the time it takes to connect jumper cables VATS resets and you THINK your cables did the trick. They in fact had nothing to do with it. TIME DID. 5 minutes to reset.
If the engine cranks...you need to KNOW what the fuel pressure is and how it behaves.
You need to test the coolant temp sensor and cold start sensor.
and most of all you need to clean and reconnect ALL the harness grounds AND the power source contacts. NOT the battery cables. Harness grounds. There are about 15 that matter A LOT.
and buy a REAL FSM, NOT a $19 haynes manual thats for a yugo.
piece of cake.
Old Apr 9, 2013 | 07:36 PM
vetteoz's Avatar
vetteoz
Originally Posted by dieseltech
when you shut the car of and come back out the car won`t even attempt to start.
http://forums.corvetteforum.com/c4-g...-corvette.html
http://www.thirdgen.org/vats_passkey_system
Old Apr 10, 2013 | 08:11 PM
dieseltech's Avatar
dieseltech
Thanks for responding guys. By not starting I mean that nothing at all happens when key is turned. I am familiar with VATS and time does not make a difference, the car absolutely will not start without being jumped and although the car is an 86 it still has less then 35000 miles. I know that vats was a poor idea at best, but I would hope that they didn`t wear out that soon. Thanks again for your help.
Old Apr 12, 2013 | 01:47 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It has nothing to do mileage! The resistor pellet or the contacts in the ignition cylinder would wear prematurely on the early VATS cars. You could have lots of starts and not many miles. Each start/stop cycle, the key would go in and out of the cylinder causing wear. I'm the original owner of my '86 Pace Car and for the first four years I owned it, it was in the US and I was not. I drove it on vacation 30 days a year. In the first four years, I put 15K miles on it, but many, many starts and stops. By the end of the fourth year, the ignition cylinder contacts were starting to wear and I would get intermittent starts. I had brought the car with me to the UK at this point and had the parts to fix it on hand as I'd read the TSB and bought the parts before shipping the car. 20 some years later and my VATS still works great.
I'm not saying your problem is VATS though. Just saying mileage isn't always the best indicator of wear.
Old Apr 12, 2013 | 05:29 AM
leesvet's Avatar
leesvet
VATS modules can fail at anytime.
Learn about VATS. Follow the test process in the FSM and that will tell you YES/NO regarding VATS.
Until your rule VATS out, its pointless to chase any other possible fault since VATS will mimic them ALL> and cause various things to appear not to work.
BTW
VATS was a GREAT idea. Like anything else it can fail. Its up to the owner/driver to educate himself and learn to deal with VATS just like how to do tune-ups on EFI cars.
Old Apr 15, 2013 | 09:57 AM
Speedjester's Avatar
Speedjester
Check the Vats... My car did the same thing a few month back.. Seems the surge or something while connecting the cables resets the system.... I only noticed it by the flashing security light..brought new key.. No problem..
To Starting problem
