rough idle after it warms up
Old Apr 9, 2013 | 09:05 PM
Erniep's Avatar
Erniep
Default rough idle after it warms up
After I take it for a ride and warm it up. I shut it off for around 20 minutes or so. Then start it, it runs rough to the point that it wants to stall. I have to give a little gas to keep it at a higher idle to keep it from stalling. It feels like it's missing at that time. After a minute, it clears up and then it's fine. What could it be ??? 1994 corvette
Old Apr 10, 2013 | 11:27 AM
Erniep's Avatar
Erniep
Any ideas ??
Old Apr 10, 2013 | 12:13 PM
davewhtt's Avatar
davewhtt
You desribed my 93 exactly.Ive been living with it but ive been told its probably injectors.When its cold or been sitting a few days it starts right up.Injectors are on my list i think # 4 or 5? Dave
Old Apr 10, 2013 | 12:24 PM
Erniep's Avatar
Erniep
I was hoping it was a sensor somewhere. I wasn't ready to change the injectors. Thanks for the great news. Lol They are on my list too. But I was hoping to do a few other things first.
Old Apr 10, 2013 | 01:34 PM
davewhtt's Avatar
davewhtt
Someone alot smarter than me may chime in and suggest this test or that?
Old Apr 10, 2013 | 02:23 PM
LongBeachC4's Avatar
LongBeachC4
Try a fuel filter first. My 85 did the same thing the other morning. Ran fine on start up, went to the station to fill up, had a bad miss when I left. Cleared up a bit but not completely. Change the fuel filter when I got home, fixed
Old Apr 10, 2013 | 05:14 PM
Erniep's Avatar
Erniep
Just changed the fuel filter not too long ago. I doubt it would have been that anyway since it only does it after it warms up.
Old Apr 10, 2013 | 06:47 PM
TommyFox's Avatar
TommyFox
How many miles?
Old Apr 10, 2013 | 06:59 PM
Erniep's Avatar
Erniep
Originally Posted by tommyfox
how many miles?
76,000
Old Apr 10, 2013 | 08:39 PM
TommyFox's Avatar
TommyFox
76,000
Original Cat?
Old Apr 10, 2013 | 10:00 PM
Erniep's Avatar
Erniep
not sure, I got the car last Aug. But they look original
Old Apr 10, 2013 | 10:05 PM
TommyFox's Avatar
TommyFox
Only has one. If original it needs to go, or be gutted
Old Apr 10, 2013 | 10:18 PM
Erniep's Avatar
Erniep
My 1994 has two converters one on each side
Old Apr 10, 2013 | 10:39 PM
TommyFox's Avatar
TommyFox
Oops ,I thought it was an early c-4 my bad Too many threads to keep up with.
Old Apr 10, 2013 | 10:47 PM
Erniep's Avatar
Erniep
Lol,thanks for the info. I have to check out the prices for cats just in case.
Old Apr 10, 2013 | 11:51 PM
lt4obsesses's Avatar
lt4obsesses
There are a few possibilities here.
When it goes into the the rough idle, does it run properly when driving, or when given gas? If so, I might suspect the Idle Air Control is sticking. It is located on the passenger side of the throttle body. You can try taking it out, and hitting it with some brake cleaner.
Check the fuel pressure regulator.
Then check fuel pressure during the event.
Clogged EGR valve is another possibility? LT4 has no egr so maybe someone else can help there. But I had a Ford 4.6 awhile back with a clogged egr.
If it doesn't run smooth at driving rpms, and/or misses continually when at temp, it could be the ICM.
Old Apr 11, 2013 | 06:04 AM
Erniep's Avatar
Erniep
It has been doing this for only a few days so I'm not sure if it's going to get worse. But as of right now, it only does it for about a minute after a warm start. Then it clears up. But I will check out the few things that you mentioned. Thanks..
To rough idle after it warms up
Old Apr 21, 2013 | 07:08 PM
Erniep's Avatar
Erniep
I had it out all day yesterday and I had no problems. Shut it off, waited about a half hour. Then started it and had no rough idle. It was cool yesterday, only in the 60s. When I was having problems, it was close to 80. So I'm guessing it is some kind of fuel vapor lock. I bought fuel line insulating wrap. So I will see if that helps the next time it warms up..
Old May 17, 2013 | 02:17 PM
Hot Rods's Avatar
Hot Rods
Any luck in fixing the rough idle ?
Old May 17, 2013 | 02:53 PM
adtbrown's Avatar
adtbrown
If it runs fine at higher idle, good indication of a vacuum leak. Also, how old is your opti? Mine (80k miles) had rough idle (not THAT bad), but I pulled my opti and quickly understood why it wasn't up to par.
