A.I.R. Pump Eliminator Kit
Old Jun 19, 2002 | 08:28 PM
chucks88's Avatar
chucks88
Default A.I.R. Pump Eliminator Kit
All of the magazine photo's I have seen of this are horrible. I had the camera out and decided to take a pic for those of you who aren't sure what it looks like/where it goes Etc. -from more of a frontal shot.
[Modified by chucks88, 7:31 PM 6/19/2002]
Old Jun 19, 2002 | 10:20 PM
Vic'89's Avatar
Vic'89
Default Re: A.I.R. Pump Eliminator Kit (chucks88)
Nice pic.
This should help some people out.
Vic
Old Jun 19, 2002 | 10:26 PM
85WHITEZ51's Avatar
85WHITEZ51
On a different note, does that camber brace really help out that much. There is allready a brace in that location just a bit lower. I think it is facotry on all cars. Does that brace make any improvemnt over just having the factory brace on.
Old Jun 19, 2002 | 11:16 PM
chucks88's Avatar
chucks88
Default Re: A.I.R. Pump Eliminator Kit (85WHITEZ51)
It sure did make a difference. I know of nobody, who after installing one, didn't like it. Do a search and you'll see. It took me an hour to put mine on and I work slow. For example: it took me 4 hours to put the A.I.R. pump Eliminator Kit on. Albeit back when I first started to wrench my car. Install time on the camber brace is different depending on the year.
Chuck
Old Jun 20, 2002 | 12:11 AM
Triple Black 88's Avatar
Triple Black 88
On another note, I noticed that you have a Power Coupler in place of the stock Accordian. I've heard that they actually make a SOTP difference. Did you feel any difference or is it a gimmic like my Power Tower. (The 1" plate that goes between the TB and Plenum) I also did the AIR Pump elim, only I got the Black set up.
Old Jun 20, 2002 | 12:17 AM
chucks88's Avatar
chucks88
Default Re: A.I.R. Pump Eliminator Kit (Triple Black 88)
The "power Coupler" was on the car when I bought it
Old Jun 20, 2002 | 01:19 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Chuck, nice pic! Do you have to get a smaller belt with this set up?
Old Jun 20, 2002 | 01:25 PM
LD85's Avatar
LD85
Default Re: A.I.R. Pump Eliminator Kit (Quik86)
Where do you get the camber brace at? How much?
Old Jun 20, 2002 | 01:40 PM
J Z06's Avatar
J Z06
Cool pic Chuck. I have the same system. Stock belt is utilized.
It sure cleans up the engine bay nicely. :lol: One dude thought I got rid of the a/c yesterday..I was like "nope...thats the air pump that was tossed".
:D
Old Jun 20, 2002 | 01:58 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default (chucks88)
:cool: right click, save as. Thanks :cheers:
Old Jun 20, 2002 | 02:11 PM
4GTWRK's Avatar
4GTWRK
Default Re: A.I.R. Pump Eliminator Kit (ld85)
We have the Camber-brace listed in the Mall under C4 specials or you can give me a call. $166.25
Dave Cooper
R-D Racing Enterprises, Inc.
573-756-6954
Old Jun 20, 2002 | 02:13 PM
4GTWRK's Avatar
4GTWRK
Nice picture Chuck, can I use it? :D
Dave
Old Jun 20, 2002 | 09:30 PM
chucks88's Avatar
chucks88
Default Re: A.I.R. Pump Eliminator Kit (84c4)
Dave
Sure. For $166.25 :D
Old Jun 20, 2002 | 09:55 PM
CFI-EFI's Avatar
CFI-EFI
Great pic! I am considering removing the pump on my '84. I understand the kit is not needed on my car. True? If anyone here has converted an '84, can they advise me on the number of the new belt needed? Thanks.
Old Jun 20, 2002 | 10:04 PM
4GTWRK's Avatar
4GTWRK
Default Re: A.I.R. Pump Eliminator Kit (CFI-EFI)
All you need is a 6-rib, 85" long belt. I just did mine yesterday.
Dave
[Modified by 84c4, 8:05 PM 6/20/2002]
Old Jun 20, 2002 | 10:23 PM
CFI-EFI's Avatar
CFI-EFI
Got it! Thanks, Dave. An 85" on an '84. Does an '85 take an 84 incher? Just kidding. Thanks again.
Old Jul 1, 2002 | 11:42 PM
jjmac_dragracing's Avatar
jjmac_dragracing
this may sound stupid but, what do you do with the hoses from the air pump once you remove the pump? plug where they go? :confused:
To A.I.R. Pump Eliminator Kit
Old Jul 2, 2002 | 12:00 AM
Triple Black 88
Default Re: A.I.R. Pump Eliminator Kit (jjmac_dragracing)
Remove 'em all!!! That's the fun part. You will have to cap the manifolds, and if you still have the main cat, you can plug that to. Mine was capped underneith already. Also the big black plastic box on the passengers side can come out to. There will be 2 wire harnesses in there, so re-mount those. They sell the caps for the manifolds at Home Depot in the plumbing section. You'll have to remove the black saucer shaped fittings to reveal the threads. The kit came with 2 rubber caps, but mine blew off under WOT :rolleyes: . I put them back on with a clamp until I got the caps.
Its actually very easy, and the directions are good. Just rip out all of the hoses and cap the one that goes under to the main cat. Let us know if you have any questions.
Old Jul 2, 2002 | 12:59 AM
RonRed89's Avatar
RonRed89
Unrelated to the AIR pump... <grin>
What did you replace your accordian pipe with? (the plastic piece that is between your MAF and TB)?
Lingenfelter sells Silicon Samco units for this, but the price is way high.
Ron
Old Jul 2, 2002 | 01:06 AM
85WHITEZ51's Avatar
85WHITEZ51
Have you noticed an idle problem? Just curious as I just removed my smog along with other things and am trying to chase down my idle problem. I wouldn't think you would but it never hurts to ask.
