Hard starting 92 when wet
Old Apr 9, 2013 | 10:37 PM
NOVICE92's Avatar
NOVICE92
6th Gear
Default Hard starting 92 when wet
Need some some help, my 92 seems to start hard when it gets wet, even just washing it.. any help would be appreciated.. thank You
Old Apr 9, 2013 | 10:46 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What parts are you getting wet.
Please tell us you are NOT washing the engine or engine compartment.
Old Apr 10, 2013 | 12:59 AM
NOVICE92's Avatar
NOVICE92
6th Gear
No sir, it even happened during a rain storm, went to start it and all it did was crank.. Seemed liked it wanted to start but wouldn't catch.
Old Apr 10, 2013 | 12:20 PM
davewhtt's Avatar
davewhtt
How old are your wires? Best advise someone on this forum gave me was start simple look for the obvious first! On my old car projects id pop the hood and run it at night looking for any ark/sparking. Good luck,Dave
Old Apr 10, 2013 | 01:57 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Good - you'd be surprised how many folks get an LT1 based Camaro or Corvette and the first thing they do is powerwash the engine and engine bay. Then complain the car won't start/run.
I'd look for bad plug and coil wires. Start it up in a dark garage and use a spray bottle with plain water and just barely mist over the wires and see if they glow or spark.
Also inspect the cap on the opti - it may have a crack.
Look for my post for the guy with the 93 that doesn't run right. Do the tune up steps, you may be able to get away with not changing the coil or icm.
Mine never ran right when really hot until I replaced the opti to ECM harness connections.
Old Apr 11, 2013 | 01:00 AM
NOVICE92's Avatar
NOVICE92
6th Gear
Thank you
NOVICE92's Avatar
NOVICE92
6th Gear
Thanks for the help
Old Apr 12, 2013 | 02:28 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Thanks for the help
Come back and let us know when its fixed.
Also - if you don't have a factory service manual - get one. best $100 tool you'll ever buy.
Old Apr 12, 2013 | 08:30 PM
NOVICE92's Avatar
NOVICE92
6th Gear
Originally Posted by jaa1992
come back and let us know when its fixed.
Also - if you don't have a factory service manual - get one. Best $100 tool you'll ever buy.
sure will
thanks again and also just received the 2 manuals today in the mail
Old Apr 14, 2013 | 03:24 AM
tahoemedic's Avatar
tahoemedic
sometimes when the ignition module goes bad, any moisture in the air can get into that system and cause it to lose conductivity. Not exactly cheap at about $100 but definitely cheaper than replacing an opti-spark or wires.
Old Apr 24, 2013 | 10:38 PM
NOVICE92's Avatar
NOVICE92
6th Gear
The coil wire was all corroded going into the opti spark, changed all the wires (chore in itself) runs great thanks for the help
To Hard starting 92 when wet
