Cost often defeats desire...not pretty..
Old Apr 11, 2013 | 12:08 PM
LoneStarV's Avatar
LoneStarV
Default Cost often defeats desire...not pretty..
I did some research on C4 control arm bushings. It's no wonder they get replaced with poly. Nobody sells replacement rubber bushings. New lower control arms i found online for 550 bucks a pop and uppers are 300. That's a lot of money just to replace your worn out bushings for stock ones. So i guess on down the road i'm going to be trying to make some poly work without driving me crazy squeaking.
http://www.gmpartsdirect.com/catalog/frameset.cfm
Old Apr 11, 2013 | 12:24 PM
doorpz's Avatar
doorpz
I've been doing alot of research lately and from what I've seen the best deal on control arms is from corvetterecycling.com. Supposedly all new oem parts. I just ordered a new outer window scraper from them and it was OEM and good quality.
http://www.corvetterecycling.com/198...trolarmkit.htm
Old Apr 11, 2013 | 12:25 PM
leesvet's Avatar
leesvet
Yup...
its appropiate with April 15th just ahead to formally introduce you to the "Corvette Tax".
You CAN get those control arms for 1/2 what you've found. Shop your local parts stores and do some googling...they are out there and you can find many jointed/adjustable uppers for less than 300...those make life sooooo easy for the alignment guy. When his job is easier...your cost is lower. Caster and Camber in vette front ends can be a very challenging task. Too often its trial & error. Finding a happy medium or "good 'nuff" is the end result. The adjustable uppers solve that problem.
http://www.oreillyauto.com/site/c/se...tte&vi=1041220
Old Apr 11, 2013 | 12:49 PM
LoneStarV's Avatar
LoneStarV
Originally Posted by leesvet
Yup...
Interesting. It doesn't say what the bushings are made of even on spec prod website. What about the lowers?
Old Apr 12, 2013 | 09:54 AM
leesvet's Avatar
leesvet
They have lowers as well...
IIRC, the stock type arm is rubber and the performance/adjustable is some form of poly. I would bet that you can order whichever since they (O'really) orders direct from a wholesaler/mfg
Old Apr 12, 2013 | 11:20 AM
LoneStarV's Avatar
LoneStarV
I looked at SPC web site. All i found was the uppers.
Old Apr 12, 2013 | 11:58 AM
aDigitalPhantom's Avatar
aDigitalPhantom
From my experience with Corvette Recycling they are a bad company to work with, for one every time i call them for anything for my c4 they always tell me the do not sell/stock ANYTHING for the c4 and older....IF they where better to work, more honest, and ever had what I need I might buy things from them as they are about 100 miles away from me
Old Apr 12, 2013 | 12:39 PM
leesvet's Avatar
leesvet
They must have recently d/c the products. It was just a few weeks ago that I looked at stock arms, upper and lower with ball joints....now its only uppers that were the 'performance' option...
I guess there is not a lot of call for C4 suspension parts from a general auto parts retailer....
Old Apr 12, 2013 | 01:23 PM
dizwiz24's Avatar
dizwiz24
dont use rubber or poly.
use metal bushings from global west - no squeaks.
Your welcome for the good advice.
Old Apr 12, 2013 | 02:05 PM
LoneStarV's Avatar
LoneStarV
Perfect if you want your filings knocked out and a kidney transplant. LOL!
Old Apr 12, 2013 | 05:50 PM
96GS#007's Avatar
96GS#007
Totally false. Ran Global West bushing for many years on the street. The car didn't have a squeak or rattle and was used on multiple 500+ mile one day drives.
Old Apr 12, 2013 | 05:54 PM
96GS#007's Avatar
96GS#007
Interesting. I've always had great experiences with them. Bought the NOS upper and lower control arms from them that I then installed the Global West bushing in. In addition, I've bought assorted other C4 parts...intermediate shaft for steering, NOS brake rotors, carpeting, etc. Always great prices, delivered as promised, and in the shape that's advertised.
Old Apr 12, 2013 | 06:17 PM
LoneStarV's Avatar
LoneStarV
Your tolerance for a harsh ride far exceeds mine. Those have to be even harsher than Delrin Bushings.
Old Apr 12, 2013 | 06:43 PM
LoneStarV's Avatar
LoneStarV
Corvette central has original upper and lower control arms. Still not cheap. $1200.00 to replace them all because Chevy didn't bother to design them so the bushings could be replaced.
http://www.parts123.com/parts123/yb....fibF~~~~A20~A1
Old Apr 12, 2013 | 08:32 PM
leesvet's Avatar
leesvet
96GS...
how are those bushings holding up?
has there been any accellerated wear against the arm mount or pivot point?
I am certain that like most other things, grease is the key. Thats not a problem in my case...I am a believer that grease is cheap...
I also kind of see the benefit and understand that with these metal bushings...any lost "give" or deflection is not transmitted to the tires...where they will be forced to tweak a but more since the hub/spindle can no longer absorb any odd side loading.
What was the cost os the metal bushings? if its reasonable I might just go that route with adjustable uppers and rebuild the lowers.. They DO make metal for the lowers or not? Uppers only?
Interesting...TIA
Old Apr 12, 2013 | 08:37 PM
mcm95403's Avatar
mcm95403
Same here - always good results from them.
Old Apr 12, 2013 | 09:06 PM
aboatguy's Avatar
aboatguy
If delalumn on the front works as well as rod ends on the rear, the ride quality may actually be better than stock..
Mike
To Cost often defeats desire...not pretty..
Old Apr 12, 2013 | 10:30 PM
LoneStarV's Avatar
LoneStarV
Mike
I went and did a forum search as well as some other sites and the feed back i read was a hasher ride with noise transmitted to the cabin. Harsh being a seat of the pants feel that differs from one owner to the next. Most that have have them admit they ride harsher and transmit noise but don't mind/care that they do.
Old Apr 12, 2013 | 11:42 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I am amazed how many have the "harsh ride" syndrone.
We have tires, shocks and springs that directly contribute to "harshness".
LoneStar, the bushings are just that, bushings. The purpose is to allow the suspension move/pivot.
Rubber is chosen by the engineers to reduce road noise and give a longer life to the pivot.
Rubber gives, and causes the suspension to load and unload in sometimes unpredictable manner.
Thus making some suspension performance mods worthless.
Since OEM bushings are no longer produced, what are the options when the rubber disintegrates?
Installed correctly, poly will give long life and remain reasonably quite.
Anyways, whats with every one worrying about noise?
Muffler elims, Corsa's, Magnaflow's and MegaWatt amps drown out all those noises anyways
Old Apr 13, 2013 | 12:12 AM
96GS#007's Avatar
96GS#007
96GS...
Interesting...TIA
They held up without issue. Being used so much on the race track, every inch of the car was closely monitored for wear and I frequently tweaked the alignment for specific tracks. As such, I know there wasn't any issue with the bushings. I just recently sold the '96, but at the time of sale I want to say the bushings had been in place for roughly 8+ years....I installed them a bit before my midwest to west coast relocation which is coming up on 7 years, so 8 or 9 years ago for the bushing install is about right.
They have zerk fittings....a shot a grease once a year was all I ever did....and an inner delrin sleeve that allows them to pivot freely. There is no metal on metal wear. I had in the neighborhood of 20k+ miles on them, with close to 5k being road course miles running primarily Hoosier R6s. The last year with the car I used Nitto NT01s...got tired of replacing front hubs after every track day.
As the pics show , they make the aluminum bushing with the delrin inserts for the upper and lower front a-arms. Cost way back when was ~$350 for the set. Probably $500 now, but who knows. Might be like Plasma TVs....$15k years ago, $900 now
