engine missing out
Old Apr 12, 2013 | 08:02 PM
sdltrl's Avatar
sdltrl
1st Gear
Default engine missing out
I have a 1990 convertible, a while back the engine started missing out. The Radio quit working at the same time, you can turn it on but all you hear is engine noise. I sounds like a ground but can't find a loose one any where. Does any one have any ideas. Thanks for any help.
Old Apr 12, 2013 | 08:23 PM
leesvet's Avatar
leesvet
You need to order a FSM to see the 2 dozen grounds that are pretty much all over the car.
You might have a bad ICM or condensor...noise supressor? The FSM will detail that as well. If its misfiring real bad....I'd say get in the distributer and investigate.The contacts there are super sensitive...so a good cleaning may be helpful.
