Serial Data Input?
Old Apr 14, 2013 | 11:17 PM
DanZ51's Avatar
DanZ51
Default Serial Data Input?
I'm attempting to convert my '86 from the "Atari" digital dash to analog gauges ('89 Firebird). I've got a 4 Out Speed Buffer, a Cruise Control Module, and a nice Racetonix header plug to connect the factory harness. I've identified all my connections except one. The "Serial Data Output" that comes from the OE instrument panel (connection D10 to circuit 461) then connects to the ALCL (terminal E) and the ECM (connection A8).
Now the FSM shows this as an output from the panel and a input to the ECM. This seems a little backwards to me, but I don't know the purpose of this connection. What is it? Does the ECM need it to operate?
Old Apr 15, 2013 | 01:04 AM
Cliff Harris's Avatar
Cliff Harris
That's an output FROM the ECM to the dashboard. It is used to calculate and display MPG.
Old Apr 15, 2013 | 01:57 AM
vetteoz's Avatar
vetteoz
If you had a '730 MAP ECM then it works the way you expect.
The VSS signal goes to the ECM first with serial data output to the CCM for speedo / cruise / etc
Old Apr 15, 2013 | 11:08 AM
DanZ51's Avatar
DanZ51
Well it's still a '165 MAF ECM. But why would the FSM show this as an "output to the ECM" (in a couple of diagrams)? The actual VSS signal goes straight to the gauge panel (C15, D11). The FSM cluster connection diagram also indicates the output as "toggling 2 to 4 volts" FWIW.
Other '165 diagrams (like the Firebird) only show this as a ALDL connection only. So I'll assume the FSM got it wrong and it is an output from the ECM to the cluster panel (for mileage, etc.)
http://www.chevythunder.com/fuel%20i...%20#1227165%29
To Serial Data Input?
