LT4 knock module questions
Old Jun 20, 2002 | 10:58 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Default LT4 knock module questions
Helping a fellow forum member and need some input on this topic. I'm not as familiar with LT1/4 cars as L98's so here goes:
1. Can an LT4 knock module be used in all '94'-'96 cars?
2. If used in '94-'95 cars, does the knock sensor need to be changed to the '96 sensor?
3. Anything else we should know?
Thanks for your help! -Jeff
Old Jun 20, 2002 | 11:47 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Re: LT4 knock module questions (18carfan)
We put one in a 94 Z28 LT1, and it did not need a new knock sensor. Just plug in the knock module and go!
Old Jun 20, 2002 | 11:53 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is a direct replacement, no need to change the knock sensor itself.
Old Jun 20, 2002 | 12:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Jeff,
It can be used in all '94-96 model Vettes. Nothing else has to be changed. Some find it to improve false knock, and unless someone has false knock there is no reason to change over. ;)
Old Jun 20, 2002 | 12:49 PM
18carfan's Avatar
18carfan
Default Re: LT4 knock module questions (Vette92)
Well, he's installing a Hot Cam and 1.6 rollers along with an Extreme Duty chain set so we though it would be a good idea. Do you agree?
Thanks Chris and everyone for the input!
Old Jun 20, 2002 | 02:30 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
He may want to try it without it if he has the means to check if he is getting false knock (Diacom, Freescan, etc). Otherwise, it is only $30 and will most likely not do any harm.
(I do know one person that lost power due to the LT4 knock module, but that was on a blower car)
Chris
Old Jun 20, 2002 | 02:38 PM
Timmy!'s Avatar
Timmy!
Funny that you are asking that question Jeff - I will be calling you to order one myself. Hopefully you have them in stock...
Old Jun 20, 2002 | 08:24 PM
STL94LT1's Avatar
STL94LT1
Jeff, you looked up the knock sensors for me a few months ago and found that the LT1 and LT4 had the same part numbers.
Old Jun 21, 2002 | 10:03 AM
18carfan's Avatar
18carfan
Default Re: LT4 knock module questions (STL94LT1)
Yes, they are the same for 1996 but the '94-'95 LT1's are a different P/N than the '96's. -Jeff
Old Jun 21, 2002 | 11:17 AM
kkonen's Avatar
kkonen
I disabled my knock sensors. Now all they do is keep the coolant in.
Old Jun 22, 2002 | 02:14 AM
Red94Vette's Avatar
Red94Vette
Jeff,
This is Aaron. Thanks for looking up that info and getting the parts sent off. It's going to be one sweet ride. :yesnod:
:cheers: to Jeff K.
To LT4 knock module questions
