Help!
Old Jun 20, 2002 | 11:22 AM
joel_222's Avatar
joel_222
4th Gear
Default Help!
I have a 1996 coupe and urgently need some assistance. Pulling the hood release lever only releases the passenger side of the hood. The driver side remains latched. I assumed that the cable had just stretched, so I attempted to pull the cable farther from within the interior to no avail. I looked from under the car and couldn't locate the cable. The summer has finally broken here in Buffalo and I'd really like to change the oil in my car, so that I can enjoy the weather in style. Any help in solving this problem would be greatly appreciated.
Old Jun 20, 2002 | 11:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Help! (joel_222)
I had the same problem when I took delivery of my Vette two years ago. The MAD hood opening tool worked like a champ. I now carry it in the hatchg, just in case.
Old Jun 20, 2002 | 12:06 PM
joel_222's Avatar
joel_222
4th Gear
Default Re: Help! (65Z01)
Where can I purchase one of the MAD hood opening tools?
Old Jun 20, 2002 | 12:13 PM
92TripleBlack's Avatar
92TripleBlack
Push down on the hood when you are releasing it. This will take the pressure off the latch and it should release as long as your cables are just stretched and not snapped.
chilihed'95coupe's Avatar
chilihed'95coupe
You can get one here http://www.madvet.com/ or you can call them and place an order over the phone. Toll Free Order Line 1-800-500-8388
Old Jun 20, 2002 | 12:34 PM
joel_222's Avatar
joel_222
4th Gear
Default Re: Help! (92TripleBlack)
I tried that too. No such luck. Thanks, though.
Old Jun 20, 2002 | 01:01 PM
joel_222's Avatar
joel_222
4th Gear
Default Re: Help! (chilihed'95coupe)
Thanks a lot everyone. I've got a MAD hood opening tool on the way.
Old Jun 20, 2002 | 01:45 PM
92TripleBlack
One more thing you might want to try is moving the car to another spot if you can. The spot you are in can be flexing the car and holding it shut. Good luck.
To Help!
