Bad ECM 1985?
Old Apr 16, 2013 | 10:41 AM
sturmmorser2000's Avatar
sturmmorser2000
Default Bad ECM 1985?
Hi i bought an 85 to restore and im having trouble with the computer.When its running it shows the check engine light and the light gives a code 12 when its running.When I jump the diagnostic connector to read the codes it just gives me the code 12 over and over.Could it be a bad ecm?
Old Apr 16, 2013 | 10:47 AM
ejscarfo's Avatar
ejscarfo
Do have an FSM? Code 12 relates to the EGR valve. I doubt your ECM is bad. Most likely your EGR valve or related components has a problem.
Old Apr 16, 2013 | 11:00 AM
sturmmorser2000
I thought code 12 was the standard going thru tests code.Yes i have the shop manual
Old Apr 16, 2013 | 11:02 AM
leesvet's Avatar
leesvet
CODE 12 IS NOT related to the EGR...
Code --12 is the system announcing -> SYSTEM NORMAL<-
You are supposed to see 12 12 12 space 12 12 12 when the system is operating as it should. ALCL jumpered. There will be a stored (if any or several) DTC in the 'space' between the 3 code 12s.
if your SES is on even without a jumper in the alcl then you have something shorted or crossed. If there are no codes stored, its shorted. try a known good ECM to test.
you cannot diagnose an EFI computer car without the correct FSM for that car. Too many codes, too many systems that require exact adjustment.
Old Apr 16, 2013 | 11:08 AM
sturmmorser2000
So your saying normally when the ses light is on when its running it shouldnt be showing the code 12?Is it supposed to blink at all or does it just stay lit up?
Old Apr 16, 2013 | 11:15 AM
ejscarfo's Avatar
ejscarfo
I apologize, didn't finsh my coffee this morning. Code 12 is the normal flash (flashes 3 times after its initialized) going into diagnostics. Any stored codes will follow.
Old Apr 16, 2013 | 11:18 AM
ejscarfo's Avatar
ejscarfo
If the CEL is on when the car is running and only code 12 appears when you pull the codes, something is wrong. If code 12 is the only code, no CEL should be lit. You have something shorted or crossed somewhere.
Old Apr 16, 2013 | 11:19 AM
sturmmorser2000
When i jump the alcl it just keeps showing code 12.Is there any other way to tell if its a bad ecm?
Old Apr 16, 2013 | 11:21 AM
sturmmorser2000
What about bad fusible links?The fuses are good.
Old Apr 16, 2013 | 11:22 AM
sturmmorser2000
The fan doesnt work either btw
Old Apr 16, 2013 | 08:49 PM
Muffin's Avatar
Muffin
Some light eading:
http://www.extreme-check-engine-ligh...%20Decoder.htm
Old Apr 17, 2013 | 12:45 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Does it run? If it does it's not likely the ecm is bad.
Old Oct 4, 2019 | 02:59 PM
DJ The nutso's Avatar
DJ The nutso
Okay, this looks like a decent place to but in...I've also got an 85 I'm trying to get on the road again, but I'm in a little over my head in some ways.
It ran when I got it, then the auto trans went out. I bought a working manual trans, and almost all the bits and bobs to get it in, but I want to check that I don't need a new ECM to have it run right..... I know I'll need a new wiring harness for the trans, and I'm planning to get a new engine harness too cause it'll be nice to have an unbutchered one, but I don't know about the computer.
Any thoughts are appreciated, and thanks for reading
Old Oct 4, 2019 | 07:17 PM
Tunedport90's Avatar
Tunedport90
The engine will run on with the automatic prom. Idle speed will be effected. You can have a prom programmed at tunedperformance.org
or a better option is use a 86-89 harness and upgrade the slow baud rate 870 ecm to a 1227165 ecm.
Old Oct 4, 2019 | 08:10 PM
DJ The nutso
What kind of effected idle? Low, high, what?
Old Oct 4, 2019 | 08:44 PM
Tunedport90
A automatic has a target rpm of 550 plus a park neutral adder. Manual transmission is 750 warm.
Old Oct 4, 2019 | 09:06 PM
DJ The nutso
So...if I can convince the thing it's always in neutral it'll idle right?
Old Oct 4, 2019 | 09:28 PM
Tunedport90
You can ground the p/n switch orange/black stripe pin b10 at your ecm. This might get the idle to 6-650.
timing curve and fueling is slightly different as well. But many have run man trans on automatic calibration.
To Bad ECM 1985?
