power steer pulley
Old Apr 17, 2013 | 01:59 PM
estormy's Avatar
estormy
1st Gear
Default power steer pulley
I have a late '93 base LT1 coupe....I need to find a replacement for my power steering pump pulley. I am not finding anything, not even a cross referenced model. Can anyone help me in finding a replacement or one that will work? It is oem GM # 10227069, metal pulley, with a serp belt. Thanks!!
Old Apr 17, 2013 | 02:02 PM
nbanwart's Avatar
nbanwart
Nobody has these if it is the same one as on the 84 Corvette. Try a junkyard or ebay and with luck you will find one.
Old Apr 17, 2013 | 02:50 PM
Silver96ce's Avatar
Silver96ce
Here is the steel pulley - http://www.corvettepartsworldwide.co...ey_p/39724.htm
I am not sure if you need to do the upgrade, if you do, try here for an upgrade to the later steel pulley -
http://www.nookandtranny.com/mm5/mer...y_Code=FD-LT1Y
Good luck!
Old Jun 25, 2014 | 10:19 PM
greendot's Avatar
greendot
this thread is barely a year old.
WTF on the price of this pulley
Regular Price USD $953.99
Old Jun 26, 2014 | 10:57 AM
ramvet89's Avatar
ramvet89
Hell - at the price I am tempted to pull the one off my 90 and sell it to you
Old Jun 26, 2014 | 11:14 AM
Silver96ce's Avatar
Silver96ce
The price was raised probably to get people to stop trying to order it and notice the large black print at top of the listing saying "**Not Available**" twice. It doesn't seem to be showing up anywhere else either - so the supply has probably dried up. Your best bet now is used from part-out car or the used parts companies. You can try See4parts and the other part-out companies in the C4 Parts for Sale/Wanted section also.
Old Jun 27, 2014 | 06:01 AM
scotth48's Avatar
scotth48
If this is a late '93, I assume it uses the single sided serpentine belt? Check with Dino's Corvette or other Corvette salvage yards for a used one.
To power steer pulley
