Fuel Pump replacement for an 85
Old Jun 20, 2002 | 01:28 PM
LD85's Avatar
LD85
Default Fuel Pump replacement for an 85
What besides the fuel pump could be changed while I'm in there. I have pretty stock 85 .
Old Jun 20, 2002 | 01:36 PM
ralph's Avatar
ralph
Default Re: Fuel Pump replacement for an 85 (ld85)
get a new fuel sock and gasket for the tank
Old Jun 20, 2002 | 05:38 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Fuel Pump replacement for an 85 (ralph)
One other thing,sometimes you need to replace the O rings for the bolts if they arent mangled when removing them.
Old Jun 20, 2002 | 05:49 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Since you are going to relieve the pressure in the fuel system, you might as well change the fuel filter also......
Old Jun 20, 2002 | 08:53 PM
LD85's Avatar
LD85
Default Re: Fuel Pump replacement for an 85 (Husker Vette)
Good ideas and thanks, I want to do this one time and get it over with!
Old Jun 20, 2002 | 09:41 PM
MrNuke's Avatar
MrNuke
Hey there, I must say that is one of the PRETTIEST C4's I have ever seen...
Nice...Just thought I'd tell you.. ;-)
Old Jun 20, 2002 | 11:05 PM
LD85's Avatar
LD85
Default Re: Fuel Pump replacement for an 85 (MrNuke)
Many thanks for the compliment :cheers: :blueangel:
Old Jun 21, 2002 | 10:32 AM
LD85's Avatar
LD85
Do I get the sock seperate of the fuel pump?
To Fuel Pump replacement for an 85
