radio and starting issues
Old Apr 21, 2013 | 02:59 PM
redvette7681's Avatar
redvette7681
Default radio and starting issues
hello everyone im new to the hi tech world of c4's and i need help,just bought a 92 lt-1 auto,bose gold amps fried so i started to put in new system,all was going well until the radio started turning on and off a couple times then turned off for good checked all the fuses and found the theft fuse was blown not sure if it was from me.after replacing the fuse i have no instrument lights and car will not crank or start,when the key is off the information system lights are very dim and if you hit the horn button the blower fan comes on.thank you for any light you can give me.
update i checked all my fuses and i have no power to the crank or fuel pump fuses,still in the dark!
Old Apr 22, 2013 | 02:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since the problem began with install of new system, remove all new components to see if operation is restored. If so, double check your installation plan.
Old Apr 22, 2013 | 06:00 PM
redvette7681
took everything out still not a thing
Old Apr 22, 2013 | 06:25 PM
Silver96ce's Avatar
Silver96ce
Did you check the fuse box underhood behind the battery? Also, IIRC on the 1992 there is an auxiliary fuse panel above the passenger hush panel (bottom of dash above knees) - you have to remove hush panel and look up into dash to see it. I think there may be a fuse for the alarm system in there.
Old Apr 22, 2013 | 06:57 PM
redvette7681
did not know about under the hood,under the dash i did, that is where the theft fuse is and that is where all my problems started. but i will check under there.
Old Apr 25, 2013 | 08:48 AM
redvette7681
did not find any fuse block under the hood.
Old May 2, 2013 | 01:46 PM
redvette7681
found the ground problem,but now disconnect the battery hook back up let it sit for a bit then the car will start and run then turn it off and i guess the vats is engaging cause it goes back to no dash lights and no crank,so all in all still lost.
Old May 2, 2013 | 02:03 PM
leesvet's Avatar
leesvet
Vats has nothing to do with any lites, dash function or ANYTHING besides the starter and/or fuel injection.
Go back thru the harness grounds and battery cables.
Follow the elec drawings in the FSM. If you do not have a FSM set, BUY ONE. You won't do well without it.....
Old May 2, 2013 | 04:18 PM
redvette7681
so your saying i would have a lcd screen and crank even if the vats was bad ,thats good to know because as of now i dont have any lcd screen and no crank at all ,so i dont have a fsm but do you know if there is a relay for the dash that might be jacked up
Old May 14, 2013 | 06:55 PM
redvette7681
280 bucks well spent it was a little ground wire under the dash.
To radio and starting issues
