Telescoping shaft wont tighten
Old Apr 23, 2013 | 12:34 PM
rad928music's Avatar
rad928music
Default Telescoping shaft wont tighten
I got a Steering Column from Ebay for may 86.
This weekend I decided to put it in.
The center Hollow shaft that telescopes wont tighten.
I took a look at the key cylinder and it looks like the guy replaced the Vat Key Cylinder with a No Vats so He must of had it apart somewhat.
Im not worried about that though.
My problem is when I put a 5/16 scew in it, it still telescopes up and down and will not tighten.
Mine had a simular problem but I locked it in postion with a long 5/16 screw.
My question is, is there a push rod thats suppose to be in the hollow shaft that presses against the wedge lock at the base of the telescoping shaft?
Old Apr 23, 2013 | 01:47 PM
jhimer's Avatar
jhimer
You are missing that rod
Good luck
John
Old Apr 23, 2013 | 04:32 PM
rad928music
Good luck
John
What does it look like?
Where can I buy one?
Old Apr 23, 2013 | 05:28 PM
rad928music
Well I did a search and this will help anyone with this problem.
It was in the C3 section.
http://forums.corvetteforum.com/c3-t...-problems.html
Old Apr 23, 2013 | 05:50 PM
jhimer's Avatar
jhimer
Any Corvette dismantler will have that rod.
Good luck
John
Old Apr 23, 2013 | 08:08 PM
WVZR-1's Avatar
WVZR-1
Corvette Central should have it for less than $10. There are two different but I believe all Corvettes used just one length, Cadillac and Olds used different lengths.
7827158 would be the correct GM # and here's Corvette Central cross from that part #:
http://www.parts123.com/parts123/yb....sort~1~cadefib
Old Apr 24, 2013 | 02:23 PM
rad928music
Yup
Got it ordered.
Now I have to order another star scew, as mine is now to short after I grinded on it trying out a longer home made rod.
To Telescoping shaft wont tighten
