Does anyone know if the Hooker Super Comp's 2151 will fit Dart Pro angle plug heads in a C4 (1988) I'm hearing all kinds of answers on this one,,and no one really knows!!
Re: Dart Pro heads & Hooker Supe Comps??? (yoslambo1@cs.com)
I've got a 383, 11-1, .555/.576 @ 236/242 Comp Custom Grind, 6" 4340 rods, with the Dart Pro 1s, that are modified extensively (read big ports), and the 2151 Hookers. Haven't put the engine in yet, but have put the headers on the engine on the stand. I don't see any problems with the tubes to head match up and these exhaust ports are big. I put the O2 sensor on the top of the collector.
Only problem that I have run up against is the 16720 Y pipe is short on the left side, about 5/8", from bolting to the collector, Hooker said they didn't know how that could happen...? Guess I put the engine together wrong and the heads are out of alignment, ha.
