MY vette WHY!!
Old Jun 20, 2002 | 09:10 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default MY vette WHY!!
OK here is the problem when its cold runs strong no codes (sweet and fast).But when it warms up 150-200 and i hammer it hard i get a code every time.then it runs kinda crappy.I have played with the timing so much i dont know what to do next.I did replace the knock sensor but dont think thats it (it would ping/knock alot at wot too) then throw a code as it was doing it i have a code 36 maf burn off module which i have had this code since i bought the car and yes i replaced it 600 bucks :eek: i had a mat sensor too low votage code to so what should i do next to fix this please help i love my vette but its like my marriage enought is enought JAY
Old Jun 20, 2002 | 11:57 PM
bogus's Avatar
bogus
Default Re: MY vette WHY!! (jparr)
this sounds like a problem with the ECU... I can never remember the next part... but when the engine is cold it runs in open loop(I think) and uses tables to determine mixture... once it warms, it is in closed loop (I think) and uses inputs.
if a part is throwing a code, make sure it is bad, or, if the circuit to it is bad.
Old Jun 21, 2002 | 02:25 AM
Ricks1989Roadster's Avatar
Ricks1989Roadster
Default Re: MY vette WHY!! (bogus)
I'm with bogus (the CF member) on this one.
Old Jun 21, 2002 | 03:33 PM
89 Bob L's Avatar
89 Bob L
Did you replace the maf relays? They are cheap, $10.00, easy to replace, and will usually fix the problem.
Old Jun 21, 2002 | 04:30 PM
FoolCrzy's Avatar
FoolCrzy
o2 sensor???
Old Jun 21, 2002 | 08:46 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
http://www.helminc.com
Stop screwing around.
Old Jun 21, 2002 | 09:23 PM
Maximus9000's Avatar
Maximus9000
Default Re: MY vette WHY!! (SLEV89)
This derned book I have shows a code 36 as an ignition system circuit error, and a code 34 as a MAF circuit or transaxle shift problem? I think this thing needs to be thrown in the dumper. Nothing else in this thing makes any sense either :mad
PeteL's Avatar
PeteL
It's an 85, no burn off relays. Needs to get the manual and stop throwing money at the fix.
Old Jun 21, 2002 | 09:38 PM
ittlfly's Avatar
ittlfly
Default Re: MY vette WHY!! (PeteL)
Yep!
Old Jun 22, 2002 | 12:34 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
i have a scan tool guys if any one knows what to look for on it that may help me i was driving in ft wyne ind tonight and i passed a slow car and when i hammered it she blew out smoke cant tell if its running rich or was carbon?? I jus dont know then the ses light came on right after that ?? jay
Old Jun 22, 2002 | 09:29 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
i had same problem and changed the map relays and the check engine light hasnt come back on yet.
To MY vette WHY!!
