So Im trying to figure out why my OD quit. It "was" working perfect. And I want to do the "by-pass the relay" mod. So my question is; Which blk/tan wire do I ground? I have 3. h
Look at the circuit diagram above
The relay is a electronic switch ; if you remove it then obviously you have to reconnect the wires that went into and out of it in order to complete the power circuit
to the O/d solenoid. (through the switch )
Refer above
Pink /blk or blk/wht (on the input side ) to the blue (output side of relay )
Tan/blk to blue means the relay you are trying to bypass is being operated for no reason
I read somewhere else it was tan to blue. It didnt make any sense to me (looking at the schematic) so I wanted to clarify. Thanks for the help! I will give her a shot tomorrow. Peace. h
That works but rather pointless because the relay would be being operated but would have nothing to switch, given the blue wire to the O/d is no longer on a "switched" relay terminal.
If you really wanted to leave the relay in place , then you could join the blk and the grn wires together at the O/d switch and then run the tan/blk control wire
from the relay to ground through that switch so that switch would manually close the relay like the computer previously did when O/d commanded
