Weirdest Problem I've ever seen...
Old Apr 25, 2013 | 12:31 AM
speedy740's Avatar
speedy740
6th Gear
Default Weirdest Problem I've ever seen...
So I have my 87 on a battery charger and everything is going good, the keys are IN MY HOUSE and the car is off. All of a sudden my heater fan starts up??? wtf is going on here? It blows air for a few seconds then cuts out for a few minutes, then starts up again and so on and so on. So at this point I had to unhook the battery cause now its starting on its own randomly and I don't want the garage to go up in flames! I read on a few sites maybe the relay may cause this? Where can I find the relay under the hood? And has anyone else heard of this or have any ideas? Thanks.
Old Apr 25, 2013 | 03:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Wow, that IS a new one.
First thing I would check voltage at batt with charger hooked up, both AC V & DC V.
I would also disconnect the - lead and check battery drain with all lights & ign off.
Old Apr 25, 2013 | 08:42 AM
JackDidley's Avatar
JackDidley
I think when the C68 blower control module goes bad, it can do that. Unplug it and it wont run. Its at the top of the evap box.
Old Apr 25, 2013 | 10:46 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Something along these lines. If you're not aware, the A/C "head unit (aka C68) goes thru a boot-up cycle when the battery is disconnected/reconnected. It's learning the blend door limits (by measuring resistance of the motor that drives the door).
Sounds like that boot-up circuit is trying to activate at the wrong time.
Old Apr 25, 2013 | 11:02 AM
leesvet's Avatar
leesvet
Your BCM when failed will allow random fan operation...
The BCM is on a "hot always" power source, so its able to fry or die at anytime during the life of the car.
get a new BCM....about $75-$100
Old Apr 25, 2013 | 02:46 PM
speedy740's Avatar
speedy740
6th Gear
You guys don't think it sounds like a relay problem?
Old Apr 25, 2013 | 04:50 PM
GREGGPENN's Avatar
GREGGPENN
No. I'm 99% sure there's no external heater fan relay. The two controls for the Climate control are the head unit and the board above the accelerator pedal. The later doesn't have a relay. (It's pictured on Batee's Corvette website.)
(OTOH, What's a BCM?)
Old Apr 26, 2013 | 03:05 AM
Cliff Harris's Avatar
Cliff Harris
The C68 (automatic) HVAC has a control module mounted on the evaporator in the airstream to keep it cool. It controls the fan speed and compressor clutch.
The C60 (manual) HVAC has a set of resistors in that position that control the fan speed. They are bypassed by the fan relay when the fan switch is set to HIGH.
Check this fuse if you have the C68 system. The relay mounts here if you have a C60 system:
Old Apr 26, 2013 | 11:22 AM
GREGGPENN's Avatar
GREGGPENN
I'd forgotten about the alum finned module sitting down inside the evap core! Is that what's termed the BCM?
What's the fuse pictured above for?
Old Apr 26, 2013 | 02:06 PM
leesvet's Avatar
leesvet
BCM
Blower Control Module
Old Apr 26, 2013 | 02:57 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by leesvet
BCM
Ah...thanks. I remember checking that component as part of my diagnostics (trying to figure out a different issue).
Note there is a trick to getting it out of the evap core. Once you remove the screws, it drops down into the core. So, get a handle on it while removing the screws. Otherwise, you'll get standing their cussing and wondering how you'll get it out of the hole!
Old Apr 26, 2013 | 04:22 PM
Dano86's Avatar
Dano86
I thought this fuse was for the under hood lights? Is it by the left front marker lights?
Old Apr 26, 2013 | 09:38 PM
speedy740's Avatar
speedy740
6th Gear
So checked that fuse and all the others and they are all working. Now have taken out that fuse, the keys still in my pocket and fan runs when it's hooked up to the battery??? The only way the fan shuts off is by unplugging the power supply from the motor????
Old Apr 29, 2013 | 06:05 AM
Cliff Harris
That fuse is in the feedback circuit that tells the HVAC control head how fast the blower motor is turning. It's mounted on the firewall next to where the heater hoses go through the firewall to the heater core (you can see the hoses in the picture).
Old Apr 29, 2013 | 06:17 AM
desertmike1's Avatar
desertmike1
Old Apr 29, 2013 | 10:36 AM
Keystring's Avatar
Keystring
I had the same problem with my 87.
Would come out to a dead battery and when I hooked up the charger, the blower motor would come on.
I replace the BCM and it's been fine every since.
To Weirdest Problem I've ever seen...
