Steering Column loose.
Old Apr 26, 2013 | 10:21 AM
dm575's Avatar
dm575
Default Steering Column loose.
Damn, just as the weather is picking up and after a winter of new injectors, full service etc etc my 91 Coupe has failed the UK MOT on excessive play in the steering column/wheel.
Found the excellent thread by Gear Jammer but still looks like a complicated fix with the added pain of getting parts over here....
Looks like the Z28 will be out when the sun shines
Old Apr 26, 2013 | 11:25 AM
BGZQ8's Avatar
BGZQ8
How many miles are on that 91 ?
Old Apr 26, 2013 | 11:46 AM
dm575's Avatar
dm575
105K, Its been maintained well and was fine on every other check but I think someone has been hanging on the steering wheel while climbing in and out over the years.
Old Apr 27, 2013 | 05:52 AM
gerardvg's Avatar
gerardvg
It is a common problem that the steering column knuckle gets worn, in some cases like happened to my vette the whole lot moved side to side and up and down. Below is what is needed to fix that..
(if your steering wheel and column moves the same)
http://www.ebay.com.au/itm/1990-1996...item27c4db9395
Old Apr 27, 2013 | 07:21 AM
yd328's Avatar
yd328
Another problem that I see happen to the GM columns is 3 bolts that come loose and need to be tightened. You have to remove the steering wheel and turn signal switch to get at them. They are inverted torx bolts, one of which I had to grind down a socket to make it fit in the column.
Old Apr 27, 2013 | 07:45 AM
ricasso's Avatar
ricasso
Just had mine fixed at Claremont Corvette this week! it needed the two pins, which they turn up themselves, so parts not a problem,and about 1/2 a days labour, its a repair they specialise in so you know your getting a good job done! I would definitely recommend them..
Old Apr 27, 2013 | 10:52 AM
dm575's Avatar
dm575
Thanks for the replies, I've removed the column so will prob contact Claremont for a quote to rebuild it.
Old Apr 30, 2013 | 11:17 AM
dm575's Avatar
dm575
Got the column stripped down and the wear is in the outer/upper casting. The pins are tight in the inner/lower part. Got a friend who is looking at reaming the holes and making some oversized pins. Fingers crossed, if it all goes back together without problems I could be back on the road this w/e
Old Apr 30, 2013 | 01:44 PM
rad928music's Avatar
rad928music
You hit the nail on the head.
On a side note I just replaced mine with one from Ebay.
I read allot about how to take these Columns apart and was scared it was difficult.
I just took my old one apart and couldnt believe how easy it is.
Now im going to rebuild it and sell or keep it for a spare.
Old Apr 30, 2013 | 01:54 PM
ricasso's Avatar
ricasso
Hope it goes well for you mate,hopefully you'll get it sorted in time to enjoy some warm weather driving this weekend!
Old May 1, 2013 | 10:48 PM
mixalive's Avatar
mixalive
That is a great idea to make oversize pins. I had replaced the knuckle on my 92 a couple of years ago @ 70k for the same issues but with new parts. Very expensive.. I permanently removed the tilt lever and move my seat back to get out of the car. But next time will make oversize pins..
Old May 4, 2013 | 02:03 AM
dm575's Avatar
dm575
Well after much cussing and many hours its back together. Over size pins and the holes drilled out by about 0.5 mm. Haven't tested things yet but fingers crossed. The slack has definitely been sorted.
If anyone else is attempting this then I found a couple of other excellent pages with good info.
http://ls1tech.com/forums/general-ma...oval-pics.html
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
I love these forums.
To Steering Column loose.
