I have -87 vette with automatic transmission. Original th700 was shot and now I have a new repaired th700. It has vette internals, except the governor is not vette version. So the springs and weights are not correct.
Original transmission was sold away so I can't take the governor from it.
Does anybody know what are the correct weights and springs for -87 vette? Springs are color coded, right?
That would really help me, because now the shifts are so terrible. I need the original point for reference for further chances.
Hope you can understand me, I mostly speak finnish
Also if somebody wants to sell me original vette governor with original springs and weights, would be nice too. The governor gear can be broken. I can pay with paypal, for example.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Your gonna need more than a "vette" governor.
I suggest looking around for a shop that has a trans dyno to help you setup the valve body and gov.
Otherwise its a lot of testing to find the right combination of springs and weights.
Plus the governor is buried behind the exhaust system making access very difficult when the pipes are hot.
You might be right, but transmission has corvette valve body. I personally don't know much but the guy who made the transmission suggested me to get "vette" governor.
We already changed one of the springs....
simply source a th700r4 coming from a vette and drop the governor,a Vette case has a V stamped on bell housing...or it becomes a trial and error job...
That's better said than done here in Finland, especially here in North-Finland.
Nobody knows the original weight of the weights and the color codes of the springs? I have some extra springs that I can try.
I believe the original shift points are around 4800rpm at WOT? That's what I'm looking for.
Not to hijack this thread, but what do the shift points feel like with a non Corvette transmission? My 87 seems to have ok WOT shift points, but at light throttle it's terrible. I've suspected that maybe it had a non Corvette transmission put it at some point before I got it.
Ok, now people understood me wrong. Transmission is vette version. Guy who made me the transmission just didn't have the correct vette governor. Shift points are now terrible, it won't even shift 2-3 at WOT. At least I didn't want to redline my engine to test the 2-3 shift.
We changed the lighter spring to little heavier, result is that 1-2 shift way too early ja 2-3 shift didn't move at all.
I just need to get the vette governor or at least to know the correct weights and springs. I have tried to google as best as I can.
Thanks, have you tried your new governor. Are the shift points around 5200 at WOT as they said in their page? That's a bit too high for me, I think.
5200 is correct for a stock L98. 6000 will not hurt the motor, it just stops making power at around 4800. Shifting at 5200 keeps the motor in its power band.
Scroll down past the tranny mounts and you will see a corvette governor. I have used this one and it works fine. You can buy their spring kit if you need to refine it a bit.
