I have q 94 C4. Replaced the battery about 6 months ago. If I do not drive it for 2 days, the battery goes dead. Alternator seems to be charging ok. Any ideas on what might be killing the battery?
I have the antenna disconnected, that went bad ages ago and I found that that killed the battery. So what could be draining the juice?
Thanks, in advance, for any help.
You have a short somewhere. I would put a voltmeter on the battery, then pull fuses 1 at a time, til you see a different reading on the meter. That will at least narrow it down, and you can leave the fuse out til you find the short. h
A sticking relay will do this. A relay, downstream from the radio fuse, on my 92, was causing this.
You can check the amp draw with a multi-meter. I did this. I set the meter up so I could see it and just pulled and replaced fuses until I saw the amp drop. I had a .227 Amp draw with the fuse in. When I pulled the fuse the amp draw reduced to .027 Amps. After you isolate the circuit causing your issue, that's when the fun of finding the actual problem begins.
Thanks for that tip. Good idea to work at the fuses. Will have fun running this down. Thanks again!
Are there any aftermarket products in the car? Stereo? Alarm? Radar? If so check the wiring.
Use a digital volt meter and pull one fuse at a time to see where the big drop is. That will tell you the circuit to look at. Take out the light fuse while testing because if the door is open then the interior lights will be on and that will cause a draw on the battery.
It does have aftermarket Radio, Amp, alarm and non-popup headlights.
Still checking. The temporary fix is to put a battery switch on the battery, turning it off until I find the short. When the battery goes dead, the doors lock. Fortunately I have a door key to open it up. The doors also lock if the car is running and I make the mistake of getting out and closing the door.
Is there anything that uses the battery power when the car is off and locked ?
One of the main users of battery power is the computer. I would recommend a battery tender over the battery switch, as every time you disconnect the battery you reset the computer and reset any radio presets.
One thing to check is look everting over in the dark and make sure some interior or under hood light isnt alwasy on. Those are easy to miss during the day.
Thanks for that information. Unfortunately.......I live in a condo, on the second floor so a battery tender is not possible. But nice to know that the computer is on with the switch off. So, for now, I'll have to use a battery switch until I find the drain/short on the battery.
If you have the C68 automatic HVAC option it is always powered so it remembers your temperature and function settings.
Keyless entry systems have to be powered all the time so they can pick up the fob signal.
The radio probably has flash RAM for its settings, so that's probably not powered.
I don't know if your car has a CTSY/CLK fuse (it might have a different name). The power for most of the dashboard goes through that fuse, so it's a good one to start with. One thing you can do is probe all the fuses in the fuse panel with the ignition off to see which ones have power on them all the time.
One possibility is the electric seats (if you have them). They can get into a weird mode where they don't really turn off. This is fairly common if you put the seat all the way back to get in and out of the car.
The underhood lamps...I've seen times when they would stay on with the hood down, bad mercury switch (or something). They have their own fuse, under the hood on the driver's side where the side marker wiring is located.
