Are PCMs interchangeable (in same MY)?
What is wrong that you feel you need a PCM to start with. Do you have codes etc indicating failure? You're wanting to buy one to have with a tune other than OE and swap back & forth?
Many questions you've not answered!
In your case, you can easily use a PCM from the same year. At worst, on a stock car you would need to reflash the gear ratio, although if you don't the only issue will be the speedo reading wrong. FX3 and the TPMS are controlled outside of the PCM in the C4. Mileage is in the CCM, not the PCM. ABS and Traction Control are also outside the PCM.
If your car is not stock, simply reflash some of the top-level parameters regarding injector sizing, idle speed, closed throttle spark advance, and perhaps timing.
Stock or otherwise, I would NOT do any WOT experimentation unless you have a wide-band O2 sensor. Having said that....stock cars are notoriously rich at WOT, so there is some room to adjust the PE values but do so at your own risk. On a modified car, all bets are off.
I would highly recommend purchasing the stand alone program cable. like mine from mad tuner
Your going to shell out at least $200.00. Well worth it once you learn.
Laptops AC vs DC. your car battery voltage & dash noise can crash both flash chips in your PCM
Its all over. You will need to repair your flash and they are hard to find. Now days. Plus you need to de-solder both flash & install sockets.
I have a spare since at one time I was flash tuning often and didn't want to be without a car if I bricked the PCM.
Both are tuned using TUNER CAT...
Mike
