Headlight repair
Old May 4, 2013 | 12:17 AM
Sprint's Avatar
Sprint
1st Gear
Default Headlight repair
My right headlight does not roll out and up when I pull the headlights on. Low miles on an 89 convertible. Help
Old May 4, 2013 | 04:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Manually rotate the **** on each headlight motor.
If they both behave the same the problem is in the electronics.
If the problem unit has a lot of slop before the light moves, time to rebuild the bushings in the gear case.
Old May 4, 2013 | 10:56 AM
leesvet's Avatar
leesvet
delron bushings. LOTS of threads on 88 and up headlite motor rebuilding. It cost $0.20 per motor to repair and about 1.5 hrs 1st time...45min 2nd time.
Old May 4, 2013 | 08:50 PM
dogfish246's Avatar
dogfish246
Hope this helps:
To Headlight repair
