rear hub nut size
Old Jun 21, 2002 | 06:33 PM
okinawa86vette's Avatar
okinawa86vette
Default rear hub nut size
What is the correct size for that big nut that holds the rear hub onto the half shaft?
Old Jun 21, 2002 | 06:37 PM
ToniH's Avatar
ToniH
Default Re: rear hub nut size (okinawa86vette)
I dunno but you need a 36mm socket to open it ;)
ToniH
Old Jun 21, 2002 | 06:41 PM
VetteNoob's Avatar
VetteNoob
Id say about 6'3" 250lbs and dumb as a rock to be convinced into holding it while you drive :D
Sorry man, couldnt resist. You can get me back for that one in a few weeks. :cheers:
Old Jun 22, 2002 | 08:53 AM
okinawa86vette
Default Re: rear hub nut size (VetteNoob)
We'll see about getting you back. You still owe me a beer.
Old Jun 22, 2002 | 08:55 AM
okinawa86vette
Default Re: rear hub nut size (ToniH)
Thank you Toni, but you're sure it's 36mm? I can't remember what I used when I swapped rear ends. I don't want to spend 15 or 20 buks on a socket to have it the wrong size.
Old Jun 22, 2002 | 12:40 PM
ToniH's Avatar
ToniH
I am pretty sure but for some reason I now cannot find the confirmation in my shop manual..
Well, I did buy a new rear wheel bearing a month ago (didn't install it yet), I found the info back then and I went and bought a 36mm socket (verified this at my toolbox). So I believe my memory is correct. But, sorry if I can't be of more help.
Maybe someone else can confirm this?
ToniH
Old Jun 22, 2002 | 12:42 PM
Oly's Avatar
Oly
On my '92, it's 36mm.
Old Jun 22, 2002 | 01:01 PM
scorp508's Avatar
scorp508
36mm on my '87 also. You can rent a 36mm socket from Autozone (if you have one) for $15 from their rent-a-tool program and return it getting all your money back.
Old Jun 22, 2002 | 05:05 PM
okinawa86vette
Default Re: (scorp508)
Thanks for the help guys. I just wanted to make sure.
It's kind of a long drive to an autozone from here in Japan, though. :sad:
Chris
To rear hub nut size
