I have used an adjustable (Crescent) or a open end to take mine out. It is a slow process.
Thanks for the response, John. I think you may have been working on a '95 (?)........ would you know if there is a sensor location difference from the '92?
I would be concerned using an open end wrench for fear of rounding, and there is still limited room for a swing of the wrench. A crescent won't work for me. The only tool I can think of is a crows foot, but even that would be iffy.
Thanks for the suggestion, ghikel. I purchased a 7/8 O2 sensor socket for a 1/2 drive (as shown in your link), but there isn't room on the right side to position the socket, and no room on the left side to position the drive. There are 2 sensors on the '92.
As previously posted, I can position a closed-end wrench, but no room to swing the wrench.
I'm not sure if the 92 is different than the 95, but I used the crowfoot socket too. After putting the car on ramps and crawling all the way under, I found that access was rather easy on both sides.
Reason: missing information
I'm not sure if the 92 is different than the 95, but I had to purchase a crows foot wrench. After I put the car on ramps and crawled under, access was easy.
You make it seem so easy, csthews. When you are 81, nothing under the vette is easy. Yes, I had my mitts on both sensors, just no room to swing a wrench. A crows foot type wrench may be the answer, but I will still need swing room, or hammer room.
I would think that the '92 and the '95 are the same sensor locations.
. I can't remember what brand I used but I got it locally.
This socket has an extended arm which allowed me to get a 3/8 breaker bar on it. I also added a small pipe to the breaker bar for added leverage. The sensor was really in there but this finally got it to move. I also soaked it with PBblaster for 24 hours before I tried to get it off. Good luck to you!
When I did my passenger side O2 sensor, I used this type .....CTA-Tools-2065-Oxygen-Sensor
This socket has an extended arm which allowed me to get a 3/8 breaker bar on it. I also added a small pipe to the breaker.....
I saw this tool, but didn't understand the application until now.
You have solved this old man's dilemma. My 81 year-old creaky bones can't wait to crawl under the vette again.
Just a little change to my prior post - I used a 1/2 breaker bar with a 3/8 adapter on it with a pipe on the end. For some reason I forgot. Again, good luck!
Using a breaker bar with a pipe extension....... you must have been working from the neighbor's property with all that leverage.
To change O-2 sensors on my 95, I bought both the slotted deep socket and the crow-foot, 1/2 drive from Harbor Freight for less than $15.00. I have leant them out to many of my Corvette Club, C4 owners and they have worked great.
As I recall, my 1992 FSM says to have the exhaust hot when removing the O2 sensors. Something about it comes out much easier and the threads do not get damaged. I took one of them out on mine, which I think was on the passenger side, and there was very little room to work. I was able to do it with the O2 sensor socket sold at the auto parts stores.
Many thanks, Silver96ce!
I got this same socket at Advanced Auto! Worked like a charm!
Thanks for the reply.
At 52, it is definitely not easy....but I guess much easier than for you. But actually, when I removed the driver's side, I used 2 swivel drives with the crows foot just to get enough room to swing the ratchet. But when I put it back on, I braved up and slid all the way under. From that different viewpoint, I could see that I had plenty of room to swing the ratchet without the swivels.
csthews, using this socket made everything quite simple.
The tab for an 18" breaker bar was key. I really had to lean on that bar, even with a heavy application of PB Blaster. The sensors were original (21 years), and didn't enjoy being persuaded to leave their nest. Chased the threads, and installation went smoothly.
I'm not sure why I decided to replace the sensors, as the vette has 64K miles, and I have read that 100K might be the time to change.
