recurve distributor on a 86?
Old May 8, 2013 | 07:48 AM
Rob31's Avatar
Rob31
Default recurve distributor on a 86?
Can I change the weights and springs on this ? Or is it all computor controlled ?
I know we have some experts here ...
Old May 8, 2013 | 08:05 AM
cgantner5150's Avatar
cgantner5150
All computer controlled in stock configuration.
Old May 8, 2013 | 09:18 AM
VanSpeed's Avatar
VanSpeed
Yes you can "re-curve" the timing but not using weights and springs. The chip in the ECU controls the ignition advance so to change requires a chip change. There use to be aftermarket chips that were compatible with a stock engine and re-tuned the fuel and ignition to give a little more power. Not sure if those are still on the market, if not you can find a tuner that can burn a new tune on a chip for you.
Brian
To recurve distributor on a 86?
