C4 -c6z06 Rotors
Old May 10, 2013 | 11:24 AM
nomad253's Avatar
nomad253
Default C4 -c6z06 Rotors
good morning folks,
I hace a c4 suspension with c5 calipers via conversion mounting bracket. is it possible i fit the c6 z06 rotors? ive ben reading they are interchangeable on some posts and they are not on others. I dont race and would really like the largest DIA. Front rotor possible that a c5 fron caliper would allow. also im looking for drilled only not slotted. the more holes the better
any insight fellas. and ladies?
Old May 10, 2013 | 12:10 PM
leesvet's Avatar
leesvet
You willing to go way UP in wheel size and the style?
'cause your C5 13" rotors are as big as you can stuff inside a 17" or 18" wheel...most styles. The larger C6 multi-piston caliper is the same as more rotor..more contact area. You;ll never know the difference though...if it even gets close to lock-up by too much slowing too quickly...ABS takes over.
Folks forget that the ABS computer has the final say in how fast the car stops...
Old May 10, 2013 | 12:19 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
drilled rotors promote stress cracks. i went to a 'slotted only' rotor.
Old May 10, 2013 | 12:30 PM
nomad253's Avatar
nomad253
yes i plan on at least 20" wheels. (let the comments begin lol) the car is not a corvette only shares chasis engineering and suspension.
i dont plan on racing tracking or anything like that so i should be good with a set of quality driolled only rotors correct? after all thats what came stock on the c6 z06.
so to be clear a simple rotor swap will do? great now where is a source for these rotors for a good price.
To C4 -c6z06 Rotors
