Fan switch
Old May 11, 2013 | 01:44 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Fan switch
Can someone tell me what I connect to for a manual fan switch, relays etc.
Old May 11, 2013 | 02:03 PM
tunedport85inject's Avatar
tunedport85inject
locate the main fan relay,rear of fender driver side.
this is the pin out of fan relay
[IMG]
[/IMG]
As you can see, ground terminal B DARK GREEN/WHITE and relay energizes and closes D-A
Put a switch to ground to terminal B and you can start main fan when you want
Old May 11, 2013 | 03:45 PM
kimmer's Avatar
kimmer
Old May 11, 2013 | 05:28 PM
383vett's Avatar
383vett
Getting hot out here isn't it Kim?
Old May 11, 2013 | 05:37 PM
kimmer's Avatar
kimmer
Sure is Willie.
Old May 11, 2013 | 06:07 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
The wiring diagram above is incorrect for a 92 model. You have two fans wereas the diagram is for an earlier single fan model.
Old May 11, 2013 | 06:46 PM
Old Ben's Avatar
Old Ben
Here is the wiring diagram for the 92 model.
When I bought mine the previous owner had cut the blue/wht wire from the fan relay to the ECM and directly grounded it so that the fan came on as soon as the key was turned on. I would not recommend that approach as it keeps the temp too low.
Cut the blue/wht wire and install the switch between the wire from the fan relay and to a ground point. Tape off the end of the blue/wht wire that goes to the ECM.
Old May 12, 2013 | 01:49 PM
tunedport85inject
Exact the same way to go...mine is an 85, but at the end just a relay ground to switch manually to ground...
To Fan switch
