engine performance problem 1984 vett
Old May 11, 2013 | 03:53 PM
1971jim0's Avatar
1971jim0
3rd Gear
Default engine performance problem 1984 vett
I have a 1984 vett that runs rough. It feels like a miss when you get on the throttle. If you go real easy on the gas the car will not hesitate at all. also, when I get on the throttle i will get A backfire through the engine not the exhaust. can any one help me.
Old May 11, 2013 | 04:50 PM
AQUILA163's Avatar
AQUILA163
How old are the plug wires and the distributor cap?
Old May 11, 2013 | 05:05 PM
1971jim0's Avatar
1971jim0
3rd Gear
all plugs,wires ,cap.and rotor replaced within 6 months problem has not gone away any help would be appreciated
Old May 12, 2013 | 09:35 PM
The Plastic Lizard's Avatar
The Plastic Lizard
Whenever someone says 84 idle problems...I say crossfire stumble.
Balance things by reading the articles here
http://www.thecubestudio.com/Crossfi...yBalancing.htm
Old May 14, 2013 | 03:46 PM
corvettenorway's Avatar
corvettenorway
ignition timing + fuel pressure !!!!!!!!!!!!
Old May 14, 2013 | 04:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
with this^.
And the "give-away" is this...
Classic sign on lean a/f ratio, and/or timing.
Check your ignition timing...check you fuel pressure.
Old May 14, 2013 | 09:37 PM
1971jim0's Avatar
1971jim0
3rd Gear
Thanks I will check timing and fuel pressure. Will let you know how it turns out
Old May 18, 2013 | 02:30 AM
Hot Rod Roy's Avatar
Hot Rod Roy
I'd suspect a vacuum leak. The top plate of the cross-fire manifold is a suspect area. There's a bunch of bolts in this area, and the gasket surface area of this plate is pretty skinny. Try tightening these bolts before you replace the gasket.
To engine performance problem 1984 vett
