How do you test a Power Brake Booster?
Old May 15, 2013 | 01:16 PM
fatboywilly's Avatar
fatboywilly
Default How do you test a Power Brake Booster?
Just wondering if I'm checking the power brake booster correctly? When I pull the vacuum hose off, the rpms go up. If I plug the hose they drop. When I put the hose back on, they drop just as if I plugged the hose. What do you think?
Old May 15, 2013 | 01:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I think that you need to apply a vacuum to the booster, and see if it holds the vacuum.
Old May 15, 2013 | 01:41 PM
383vett's Avatar
383vett
Use a Mytivac with a bunch of adapters and apply vacuum to the booster. You'll have to pump a lot because of the large volume. If it holds vacuum, it's fine. If it doesn't, it needs to be replaced.
To How do you test a Power Brake Booster?
