Corvette Horn Button Assembly
I just bought my first Corvette (an '86 with a '94 body kit) and I am running into an issue. The horn assembly is total garbage. In other words, nothing is there....so it doesnt work!! All I have is the horn button itself with a wire hooked up to it. The button sits flush against the wheel... so it can't be pressed or anthing. So my question is this. What parts are needed inside of the steering wheel to get the horn to work?, does anybody have any pictures that will help me with assembly? Thanks so much for the help!
You might contact Jason at Vette2Vette about what parts are needed inside the steering wheel; I'm sure he can provide quality used parts to fit your needs.
When you say that "all you have is the button with a wire", is the wire plugged into the socket in the wheel hub? It's a pretty simple switch inside the horn button. Probably has some corrosion in the contact area. With the button out of the car, test the switch with a volt/ohm meter as you push on the button. You can carefully pry the switch out of the plastic button, clean up the contact areas, then apply a very light coating of white grease to prevent corrosion. Clean up the two mounting tangs that snap into the wheel hub as well as the metal areas of the wheel hub where the horn button fits, and apply a little grease here, too. Try the continuity test again, snap the button in place (the horn will probably sound as you install the button), and you're done!
Your new Corvette is 27 years old! It's not "garbage". It just needs a little TLC! Welcome to the forum!
(Please be sure to report back here to let us know how you solved your problem! We're all learning together.)
