MAT sensor relocation
Old May 17, 2013 | 01:03 PM
Mr.Grandpa2U's Avatar
Mr.Grandpa2U
Cruising
Default MAT sensor relocation
Has anybody replaced the rear power coupler and installed a "Relocation Kit"? My '96 has a damaged stock coupler, so I was going to replace it with an aftermarket (smooth) one. According to "Corvette Central" the kit is neccessary, and a hole should be drilled in the air filter housing. The catch is, the car has an SLP cold air intake on it. Can the MAT sensor be relocated on it? Any opinions would be appreciated!!
Old May 17, 2013 | 01:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My prior '88 had the SLP cold/ram air intake so I drilled a hole in the LH side of the air filter lid and installed the relocated MAT sensor into that location.
Old May 17, 2013 | 05:37 PM
Mr.Grandpa2U
Cruising
All I needed to know, THANKS!
Old May 17, 2013 | 07:59 PM
leesvet's Avatar
leesvet
yeppers...
The idea is to get a taste of the air going in the engine for combustion, so the logical place is in the air filter box or duct at a place where its not heat-soaked and sending false data to the ecm....
Mines in the filter box.
Old May 18, 2013 | 12:31 AM
vetteoz's Avatar
vetteoz
Originally Posted by leesvet
where its not heat-soaked and sending false data to the ecm.....
Some enlightening reading for MAF owners
http://www.thirdgen.org/techboard/po...01-post20.html
http://www.thirdgen.org/techboard/po...336-post2.html
http://www.thirdgen.org/techboard/po...315-post3.html
http://www.thirdgen.org/techboard/tp...-does-mat.html
Old May 18, 2013 | 12:41 AM
LT4 F45's Avatar
LT4 F45
Here is how i installed the smooth intake system with stock MAT on my 96. I punched a hole for the sensor at about the same place that it was originaly and another one for the opti vent tube... Hope that help...
Old May 18, 2013 | 08:28 AM
Mr.Grandpa2U
Cruising
Excellent photo. Just what I was hoping to find out!! Thank You
Old May 18, 2013 | 08:56 AM
LT4 F45's Avatar
LT4 F45
If you need any other angle i can snap them for you...
Old May 18, 2013 | 10:35 AM
leesvet's Avatar
leesvet
without even reading your links, I Digress !
after slowing down and taking the time to start my brain before putting my fingers in gear.,...
my term of "false data" ...is, FALSE. in this application at least.
the MAT measures the temp of air thats actually entering the combustion chamber. So, it (ecm) needs to know the temp of that air thats entering and if it is heated by the intake, so be it. Thats the temp of the air that the ECM needs to know..not the ambient temp or the temp in Boston...
The REAL purpose of relocating the MAT is to get cooler air readings and CREATE FALSE data for the ecm to maybe get a little bump in fuel to go with the cooler air the ECM is seeing from the new MAT location...
To MAT sensor relocation
