Tuner Pro Rt and 95 Vette
I have ordered the new USB/16 pin cable from aldlcables.
I know I need to download 2 files but dont know where to get them or what to do with them after down laod.
Can someone tell me the needed 2 files for the 95 LT-1 Vette and where to put them so Tunner Pro Rt finds them.
I DO NOT want to burn with tuner pro, just use it to read codes and engine data.
Thank You
8Valve
http://www.tunerpro.net/downloadApp.htm Go to the site, download TP RT then on the right you will see 7 links. Move mouse over the "Downloads" link and drop down to "definitions" and click. You will be taken to the page where you can download two things; the "Bin Definition" and the "Datastream Definition". The Bin D. is for modifying you bin file in the computer and the other is for data logging/ reading your computer. Find the ones for your car and right click on them and then do a save to your desktop. You can the open TP and load them in to the program. Good luck.
