electric fans dont work
Old May 20, 2013 | 01:41 PM
ch@0s's Avatar
ch@0s
Originally Posted by jerryseng
Thanks for the info, I will go thru it.
Red 10 and 11 are going to be your trigger wires.
10 DK BLU 473 Cooling Fan #2 & #3 Relay Control (PCM Supplies GROUND)
11 DK GRN 335 Cooling Fan #1 Relay Control (PCM Supplies GROUND)
Old May 20, 2013 | 11:12 PM
Cliff Harris's Avatar
Cliff Harris
I am not familiar with all the initials that every one uses.
ALDL = Assembly Line Diagnostic Link. It's the connector just above your right knee that the scan tool connects to. The connector changed over the years, so pins A & B might not be the right ones for your setup. See these links:
http://forums.corvetteforum.com/1574918379-post18.html
http://forums.corvetteforum.com/c4-t...n-96-cars.html
http://corvettephotographs.com/c4vettes/codes.htm
http://forums.corvetteforum.com/1576116036-post35.html
ECM = Engine Control Module (also Electronic Control Module). It's the car's "computer". Later years called it a PCM for Powertrain Control Module.
CTS = Coolant Temperature Sensor. It tells the ECM what the temperature of the coolant is. The ECM uses that information to determine spark advance, fuel injector pulse width and idle speed (actually a bunch of other stuff too). The ECM turns on the radiator fans based on the coolant temperature.
Old May 21, 2013 | 09:29 AM
jerryseng's Avatar
jerryseng
Cruising
Thanks Cliff for the translation. I will print out the links you listed.
