Hood
My question is:
How do I go about getting the hood up at this point? I have heard that I have to have the front passenger quarter panel removed and go up through there, then heard that I shoudl be able to release the hood latch from the very front underside of the hood. Keep in mnd please this is Mom and I am learning. I want to get the hood on the car so I can get to the battery and replace that and get the car off of jack stands and drive. Perhaps even sell.
On a side note Timspeed had put brand new corbeau race buckets in and I hate them. Never used them maybe one time he took it for a spin after the seats. I want to lose the race buckets and get some other perhaps stock seats. I do not know what to do with this vehicle and therefore turned to the only place I know he would have came to. I do hope that someone on here can assist me with this knowledge. I thank You all in advance.
However, I have to get the hood up off of the vehicle first as the hood has been dropped in place and can not be moved at the time so to get to the area that the tool was accessing I assume I have to remove the front passenger quarter panel? Plus the hood? to get to the point where the pic shows the tool being used? I am new here and have limited knowledge of all of this and was left to tend to. I Thank You for any and all info you may supply all will be greatly appreciated. Thank You in advance.
If you search on here there was a thread a few months ago on how to insert this, and what you are trying to push, blindly.
The tip of the tool is sitting next to the hood release. It's L-shaped tips protrude down into the slot where the release "lives". The release is the darker 1" bar-looking piece immediately to the right. At the top of said bar, you'll see a cable coming from the right. When you pull the hood release that cable pulls the bar to the right (inward). On the passenger side, it'll be pulling to the left (mirror image).
You can "pop" each side independantly. In other words, do one side at a time.
Just below the circle in the picture, you'll see the rubber hood seal, You'll probably find it necessary to work the tool THRU the seal-to-hood contact point -- to get to the latch. (Think what it would be like to jam a coat-hanger thru the weatherstrip at the rear of your window to unlock your car. Same principle.
This difficulty is why people often install short loops of cable that are attached to that same release lever. When the main cable is broken, you just pull your emerency stub.
Depending on where the cable is broken, you might also be able to pull it from the windsheild wiper area. But, I'm guessing the tool is your best bet.
Once you have the hood open back off the locking nut on the release cable, tighten the tensioning nut till the hood will NOT hold the hood down. Then back off till the latch just engages yet still releases. Once you have it set, tighten the locking nut and you are done.
Since it's been "sitting" (assume unstarted) for >6yrs you may need to have it hauled to a garage for fuel & fluid change before starting it up??
Thanks for the update. I was a little concerned when you said he'd "left the building".
If the hood alignment is off from removal, that tool might not help. As this member had to dismantle the inner finder, then the hood latch pin. http://forums.corvetteforum.com/c4-t...ld-issues.html
We met years ago when he was still driving the vette.
If I can be of assistance send me a PM here.
I have a pair of 92 Sport Seats.. Black and Red I will be selling.. everything works but the driver side needs the lumbar 'bag' if you will
lumbar pumps work as do the side controls, there are no seat rails though so you would need to locate those, although I have one manual rail set
if interested email me vettxtc @ gmail . com (just remove the spaces)
So I know some other friends of mine took out some hood hinge bolts thinking they could remove hood that way. There is a few bolts left to remove from there but is that possible to remove the hinge bolts & lift the hood from that angle first? Freeing the front & driver side in order to free what is jammed or hung on passenger side? If so can someone send me a pic or have a link of hwo many bots & where they located in the hood hinges ?
Thank You all so much !!
