1990 runs won't idle
Old May 20, 2013 | 10:22 PM
40flier's Avatar
40flier
Default 1990 runs won't idle
Stalls, have to keep rpms up to run. Mass flow sensor?
Old May 21, 2013 | 07:13 AM
AirForceOne!'s Avatar
AirForceOne!
Could be a lot of things! How many miles and which tranny?
Our 90's don't have a MAF Sensor.
Check the Air Idle Control Valve, vacuum leaks, fuel pressure. When's the last time she had a tune up? (plugs, wires, cap, rotor, fuel filter)
Old May 21, 2013 | 07:50 AM
40flier's Avatar
40flier
Estate car, convertible, 52K automatic no. 2 beauty. Probably less than 100 miles per year for last three years.
Inherited by family member, no history, drove flawlessly last year before intermittent failure to idle. May start/drive well then stall at idle, keep the rpms up and runs until next stop light.
Old May 21, 2013 | 08:31 AM
Churchkey's Avatar
Churchkey
Suggest ohm testing the injectors when cold & hot. Stock 90 injectors fail due to corn gas. IIRC ohms should be 14-16 however a forum search will provide the exact resistance. Many here use Bosch 111 injectors from Jon @ FIC
http://forums.corvetteforum.com/c4-t...questions.html
Old May 21, 2013 | 08:34 PM
SunCr's Avatar
SunCr
If you haven't, check fuel for water. Remove inlet from fuel rail or at the filter. Attach hose to line. Place line in a coffee can. Turn key but don't start it and it'll squirt maybe a quart. Transfer fuel to a Mason Jar and see if water settles out of it.
To 1990 runs won't idle
