WINALDL Software
Old May 21, 2013 | 07:08 AM
jseremba's Avatar
jseremba
Default WINALDL Software
I have a 1984 Corvette with manual transmission. I want to set up the TBIs. I have downloaded the software and thinking of buying the cable.
Most important to me. Does this software help me set up the motor? If it does. How do I use the information it will give me?
Can I use the software to change parameters. Or do I need something else to tell me how to adjust the TPS. can it modify the ECM?
Thank you for the help.
Joe
Old May 21, 2013 | 08:20 AM
JackDidley's Avatar
JackDidley
WINALDL will give information from the sensors. O2 readings, IAC, engine speed, temp, etc. Its a nice scan tool. It will not reprogram the ECM for you. With an 84, Im not sure whats available for that.
Old May 21, 2013 | 09:40 AM
jseremba's Avatar
jseremba
so is it worth the 60.00 cost of the cable. Is this useful information
thank you
Old May 21, 2013 | 11:47 AM
JackDidley's Avatar
JackDidley
It is worth it. Check and see if Tunerpro RT will work with the 84. It will scan and allow you to reprogram the tune. Tuning on an 84 is a bit different than the newer cars so Im not sure how do-able that part is.
Old May 21, 2013 | 12:44 PM
jseremba's Avatar
jseremba
Default Software
Thank you
Old May 21, 2013 | 01:36 PM
jseremba's Avatar
jseremba
I went to the website. But they do not have a contact us tab. The software will connect. but I do not know if it will do more than winaldl
Old May 21, 2013 | 01:42 PM
JackDidley's Avatar
JackDidley
Start with WINALDL first. Search for a Tunerpro ADS or ADX file for your 84. If you find it, you should be able to log with that. You will need an XDF to burn chips. That presents a whole different hardware problem though.
Old May 21, 2013 | 04:37 PM
jseremba's Avatar
jseremba
Yikes
Old May 21, 2013 | 04:55 PM
jseremba's Avatar
jseremba
So are there other ECMs that work with my car
Old May 22, 2013 | 07:39 AM
vetteoz's Avatar
vetteoz
I don't see any files for CFI cars on the Tunerpro site
http://www.tunerpro.net/downloadBinDefs.htm
So are there other ECMs that work with my car ?
People that are serious about tuning CFI engines generally upgrade to a later ECM like the ones from early '90 TBI trucks that are much better supported in the tuning community
Or this alternative with flash ( no chips ) tuning
http://www.dynamicefi.com/EBL_Flash.php
Old May 22, 2013 | 08:38 AM
jseremba's Avatar
jseremba
Default Ecm
This is great information.
Thank you
Joe
Old May 23, 2013 | 02:28 AM
Cliff Harris's Avatar
Cliff Harris
The ECM program is in EPROMs on these cars. The only way to change the program is to remove the EPROM, erase it and put in new parameters with an EPROM burner.
The ECM puts out a series of hexadecimal bytes. You need a definition file for your year and ECM that tells the scanning software what the bytes mean. The order and meaning of the bytes changed from year to year.
Old May 23, 2013 | 02:51 AM
tunedport85inject's Avatar
tunedport85inject
i'm not a CFI guy,but the limit of your ECM is the low support it has.There are not hacking for your specific .bin file.As just told,without .bin ,.XDF,.ADX file you can't use TUNERPRO RT to edit parameters into your .bin file.It'is simply an unsupported hardware.What you can do:
1)if you'r going deep into modifying your engine why don't consider to grab a TPI intake and an 165 ecm with wiring from a salvage?TPI with 165 ECM (86-89) open the doors to a world of new opportunity about tuning.
2)As told later TBI truck used improved version of your TBI (CFI) injection system down in the first 90's,if you find support on specific forum like wiring repinning ecc.you can find some stuff like this.
3) There are some aftermarket throttle body injected EFI ECM that use simple software and programming device you can use on your CFI C4,this is entry stuff but do his job,in this case you have to spend ...
http://www.summitracing.com/parts/fst-30226-kit
depend on how serious you are about modifying ...cam,heads,...
Old May 23, 2013 | 04:55 AM
jseremba's Avatar
jseremba
Oh my gosh a very informative post thank you. I thought in order for me to go TPI I would have to change the accessory locations. All I want is for the car to run properly and reliably
thank you
Old May 23, 2013 | 08:38 AM
tunedport85inject
In this case you don't need to work with your tune or edit anything inside,try scan &tune section of the forum to go deeper about...
Old May 23, 2013 | 09:16 AM
jseremba's Avatar
jseremba
Thank you. And I was not complaining.i am very impressed with the knowledge and amount of information the forum offers.
thank you all
To WINALDL Software
