TunerPro RT wont run
Old May 21, 2013 | 09:45 PM
8valve's Avatar
8valve
Default TunerPro RT wont run
I downloaded Tunerpro RT from the Tunerpro.net site. The install, 'appeared' to be normal. When I try to execute Tunnerpro RT, I get the error msg;
Not a valid Win32 Application.
I am running this on a Dell Laptop, Windows 2000
Any Ideas ?
Thanks 8valve
Old May 22, 2013 | 07:40 AM
captainkawasaki's Avatar
captainkawasaki
If your other apps open ok (like notepad and calc and stuff) then I'd just do an uninstall/reinstall. If the other apps give the same error then you have a pretty serious malware infection and you should use the Kaspersky Virus Removal Tool to get rid of it. If that doesn't work you can whip out Combofix but that tool is much more destructive than Kaspersky.
Old May 22, 2013 | 08:08 AM
8valve's Avatar
8valve
Thanks for the reply. The Dell/Win 2000 run perfect in all apps. No issues whatsoever in anything the Dell/Win2000 does. Tonight, I will uninstall and reload. Maybe the Tunerpro RT download got a glitch while downloading ?
8Valve
Old May 22, 2013 | 11:16 AM
captainkawasaki
Should have read your initial post more closely. If you only downloaded the executable then there was probably a lost packet or incomplete download initially. Re-download and run again and you should be golden.
Old May 22, 2013 | 03:13 PM
8valve's Avatar
8valve
I downloaded "Setup Tunerpro rt V500_8144.exe"
I just loaded it on a Windows XP desk top. It executes and appears to run. Of course no car in the house to get data from.
Used the same down load and once again tried the Dell Laptop with Windows 2000. Nope, wont execute. Same error msg
"Not a valid Win 32 application"
Maybe Tunerpro RT does not like Windows 2000.
I used to run Tunerpro RT Version 4.XX when I had my 87 and it ran fine ????
8Valve
Old May 22, 2013 | 11:08 PM
vetteoz's Avatar
vetteoz
So reinstall and use TP V4 if it works
V4.14 available here
http://www.tunerpro.net/downloadAppLegacy.htm
Old May 23, 2013 | 08:08 AM
8valve's Avatar
8valve
I have the Legacy 4.14 version on cd. However I cant find a
.ads data stream for my 95 LT-1 to use on version 4.14. All I want to do is read and clear codes and also see engine data. Thus, I have been told I only need the data stream.
I have EE_manual.adx loaded with Tunerpro rt V5 on the Desk top Windows XP computer and it appears its runs well.
8Valve
To TunerPro RT wont run
