Vett is VERY low
Old May 22, 2013 | 03:37 PM
henkdeswardt's Avatar
henkdeswardt
Default Vett is VERY low
Hi there.
Can anybody please help me. My '90 C4 is very, very low, only about 4" to 5".
It is creating quite a bit of driving problems for me.
It looks like it has a fiber suspension in front (I think - my '81 had a fiber suspension....) as indicated in these photos.
Is there perhaps a spacer that may have been removed by the previous owner at the position indicated?
Thank you.
Henk
Old May 22, 2013 | 03:48 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
It very well could have been lowered by a previous owner. Otherwise you could have a sagging or cracked front spring. I believe stock ride height is only about 5.5" of ground clearance, for a coupe. And yes the transverse leaf springs are fiberglass.
Old May 22, 2013 | 04:07 PM
henkdeswardt
Thank you.
How can I check/test for cracks?
It is a Convertible.
If the stock is only 5.5", then I'm not far off.
Would there be a "Spacer" at the blue arrow as standard?
Thank you.
Henk
Old May 22, 2013 | 04:11 PM
tunedport85inject's Avatar
tunedport85inject
the front leaf spring is mounted on two rubber wedges,lowering the front end require to trim this wedges or use lower than stock.looking at your shock absorbers it seams to be oil leaks meaning the shocks are gone...If your shocks are gone the entire weight of front end is supported by the monospring as results it seats lower ....
http://www.digitalcorvettes.com/foru...ad.php?t=79763
Old May 22, 2013 | 04:30 PM
henkdeswardt
Thank you, Excellent info!
How do I check the Shock? Maybe that is part of the problem.
Where do you actually measure the ground clearance? Sounds like a stupid question, but my car has a frond kit on, so I can measure the clearance there, but I can't really compare it to a stock car.
Thank you.
Henk
Old May 22, 2013 | 04:37 PM
shakedown067
Convertibles sit about an 1" higher, so it should probably be closer to 6.5"....They have MASSIVE amounts of fender gab (the space between the tire and the fender). That's for the added clearance of the X-bracing under the car that hangs down lower than the frame.
To check the shocks, just push down quick on the front end of the car. It shouldn't bounce around. It should go up and then rest into place quickly. Now, they could still need to be replaced though.
To check for ground clearance. Just measure from the bottom of the frame, from just behind the front tire, and again just in front of the rear tire.
Old May 22, 2013 | 04:50 PM
henkdeswardt
Thank you!
Old May 22, 2013 | 05:03 PM
shakedown067
Which I could help you with what the actual ride height should be, but my car hasn't been at stock ride height for quite sometime.
Old May 22, 2013 | 09:39 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Check the shocks, your Delcos/Bilsteins may be bad. My front rode so low the tire rubbed the inside of the wheel well when I hit bumps. When I removed my shocks I could move them by hand. When I installed new Bilsteins the ride height went up and the wheels stopped rubbing the wheel wells.
Old May 23, 2013 | 10:46 AM
henkdeswardt
Wow, shakedown067, sweeeeet ride!
Thank you, I'll check the shocks.
Old May 23, 2013 | 04:21 PM
tunedport85inject
the same happened to me, the fender gap was about two finger high.When i had the shocks down i was able to compress they by hand and they remained compressed as soon i left them!!completely gone...
Old May 23, 2013 | 04:27 PM
tunedport85inject
just a question: was you to remove the sway bar from your front suspension or the car is missing it?
Old May 24, 2013 | 12:03 AM
henkdeswardt
What is a "sway bar"?
The photos were taken after we had to remove the power steering for repairs.
Is there something else that is supposed to be there?
Old May 24, 2013 | 12:30 AM
Cliff Harris's Avatar
Cliff Harris
Since I just did this...
That's not the only thing missing. The steering rack isn't there either.
[EDIT]
Oops. Looks like he got the reply in before I did.
You have to remove the sway bar to get the steering rack out.
[/EDIT]
Old May 24, 2013 | 12:45 AM
henkdeswardt
Thanx.
Do you perhaps have a photo?
Old May 25, 2013 | 07:46 AM
tunedport85inject
Ok,so the sway bar is out for maintance...this is the sway bar,the black bar parallel to the rack pinion
Old May 25, 2013 | 09:36 AM
henkdeswardt
Thanx.
You took it out just to help me!
To Vett is VERY low
Old May 25, 2013 | 12:02 PM
tunedport85inject
it's strange but...if you type the name of parts your serching for and select immage from google tool bar ...dang!lots of pics of these parts...
Old May 25, 2013 | 12:21 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Springs hold the car up.
Shocks dampen the springs.
Anti-roll (ugh "sway") bars minimize body roll.
Each of these have a specific function and complement each as a trio.
Unless you have weak springs, shocks have nothing to do with ride height. And are not the choice to change ride height.
Unless your a rustang or rice owner then all bets are off....
Old May 25, 2013 | 01:18 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I see you are in South Africa, so some of your terminology there will be different than here in North America. (You would call the hood of the car a Bonnet, right?) Sway bars are also called anti-roll bars.
Here's a close-up of how it should look on the Vette:
